Hello all,
I've updated to version 6.4.0RC-6 on debian lenny, suggested me by the
debian alert actualization system. That´s working ok with my mapsets with
dbf driver. Then I´ve installed postgresql and translate maps and data to
this database with the appripiate commands. Now the problem is that search
of attributes by clicking on an entity on the map window-edit mode (tried
with both pg or dbf drivers) show me a 'No atributes found' dialog box. But
they seem well connected with the map, the tables are there and works fine
the click 'view mode'. Also I can select with right click on the map's list
the option 'show attribute data' of the current selected map.
Have anyone experienced this problem? What is the thing(s) I'm forgetting or
doing in the wrong way?
Thanks to the community for this Grass excelent work.
Luis Carcedo
