I appear to have broken Grass
I am using Grass 6-4-4-1 on a windows 8.1 machine.
I have used Mapinfo in the past and spent most of today learning the ropes.
I have managed to load OSGB data and create and modify maps, but as the day has gone on the display has become slow and unresponsive.
I thought this may be because I had loaded too many large layers, so I created a new mapset with the plan of zooming to my area of interest, making it a region and only loading the parts of the maps within the region.
Even this simple two-map mapset wouldn’t display – it seemed to be refusing to zoom to the map, or thinking it was outside the region.
I have obviously tried fiddling with map settings and regions trying to get my blank screen to show a map.
Now, whichever mapset I chose (including the demo mapsets) I get the splash screen (with the ancient map), the main screen appears for a fraction of a second, and then both disappear.
I have tried restarts and even a full reinstall, but I can’t actually get into the program.
Can anyone think what I have broken… at the very least, is there a way to ensure every single ini file/registry key etc. is cleaned out so I can start completely from scratch again?
All help gratefully received.
Regards
Neil
Neil Wyatt
