[GRASS-user] GRASS on debian
I'm running debian squeeze, and installed grass via synaptic.
It says it is installed okay, but I can't find it in the gnome menu.
Any hints?
Nick
Hi Nick,
Just fire up a terminal and just type :
grass
HTH,
Pierre
2010/12/1 remoray <remoray@optusnet.com.au>:
Any hints?
Nick
grass-user mailing list
grass-user@lists.osgeo.org
I would also expect that after installing debian package the menu will
be updated.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
be updated.
also on Ubuntu (user since 6.06) it is never updated. Always had to
create the shortcut manually or to launch GRASS from the terminal.
-- Giovanni --
2010/12/1 Giovanni Manghi <giovanni.manghi@gmail.com>:
be updated.
I guess grass package in ubuntu is taken without any modification from
debian (my wild guess). So fix debian package first.
Martin
do not expect having a shortcut on the desktop after installing the
program. Grass already installs its menu entry on most of the desktop/window
managers.
sorry, I'm not speaking of desktop shortcuts, but about menu entries. No
menu entries on Ubuntu, since always, AFAIK.
cheers
-- Giovanni --
Yes, I can confirm that. I don't have any menu entry neither on OpenSuse.
Pierre
2010/12/2 Giovanni Manghi <giovanni.manghi@gmail.com>:
managers.
cheers
-- Giovanni --
Martin:
package the menu will be updated.
modification from debian (my wild guess). So fix debian
package first.
yeah, we certainly started it (putting icons in place, etc), I
forget where we got with it to though. The basic thing is that
the "grass.desktop" file needs to be copied into
/usr/share/applications/ if it isn't already.
http://svn.debian.org/viewsvn/pkg-grass/packages/grass/trunk/debian/
ah, we were waiting on a file to show up, which now has.
http://svn.debian.org/viewsvn/pkg-grass/packages/grass/trunk/debian/grass.desktop?view=markup
that file looks like it still needs some revision, but the
important line is Terminal=true.
For WindowMaker-style WMs (like Fluxbox) the appropriate file
is "grass.menu":
http://svn.debian.org/viewsvn/pkg-grass/packages/grass/trunk/debian/grass.menu?view=markup
Hamish
Hamish wrote:
The basic thing is that the "grass.desktop" file needs to be
copied into /usr/share/applications/ if it isn't already.
btw, this file doubles for both the desktop icon and the Gnome menu
entry -- the menus are self-assembled from the Categories= line.
Hamish
