[GRASS-user] Grass on macos 10.7 aka Lion
Hi there,
Latest William's binary (6.4.1) is working in Lion. In an upgraded machine there is no major problems to run it both with tcltk and wxpython. In a fresh installation, I got problems to point to the correct GISBASE directory, the terminal ended in the text gui and once I pointed to where grass data was, it starts with the following warnings:
CFURLCreateWithString was passed this invalid URL string: '/System/Library/CoreServices/CommonCocoaPanels.bundle' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
wish warning:
Wish[3284] <Error>: kCGErrorInvalidConnection: CGSGetWindowTags: Invalid connection
Aug 1 19:04:51 vpn1-22.vpn.uv.es Wish[3284] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
