Hello, I’m trying to work with temporal series using GRASS GIS, but when I try to register maps an error occurs:
Reuniendo información del mapa…
ERROR: ascii,Definir tiempo absoluto válido para mapa <,25,26,ordinal not
in range(128)
I have five maps:
MODIS_2015250_h12v12
MODIS_2015251_h12v12
MODIS_2015252_h12v12
MODIS_2015253_h12v12
MODIS_2015254_h12v12
The secuence of commands is:
t.connect -d
t.create type=strds temporaltype=absolute output=ndvi title=“prueba ndvi” description=“prueba ndvi” semantictype=mean --o
t.register -i type=raster input=ndvi maps=g.list raster pattern="MODIS*" separator=comma
start=“2015-09-07” increment=“1 days”
any ideas about how to solve it?
Andrés.
On Sat, Mar 11, 2017 at 9:49 PM, Andres Solarte
<e.andres.solartec@gmail.com> wrote:
Hello, I'm trying to work with temporal series using GRASS GIS, but when I
Reuniendo información del mapa...
in range(128)
Just wondering:
- which operating system do you use?
- given your name "Andrés" - do you have special characters in the path?
Best
Hello Markus
I’m working on Ubuntu 14.04 and the path is /home/andres/Escritorio/pruebas
Regards
2017-03-12 7:08 GMT-03:00 Markus Neteler <neteler@osgeo.org>:
in range(128)
Just wondering:
- given your name “Andrés” - do you have special characters in the path?
Best
Hola Andres!
Bienvenido a la lista! I’m glad that you write here
I regularly use t.register with MODIS products, and haven’t found that ERROR you describe. Moreover, I did some testing, just creating ad-hoc maps, creating the strds and then registering those maps and all went fine. I cannot reproduce the error that you get.
Here are my steps:
for i in seq 1 5
; do r.mapcalc “prueba_andres${i} = 3” ; done
100%
100%
100%
100%
100%
GRASS 7.3.svn (latlong_wgs84):~ > t.create type=strds temporaltype=absolute output=ndvi_andres title=“NDVI prueba” description=“prueba tesis” semantictype=mean
GRASS 7.3.svn (latlong_wgs84):~ > t.register -i type=raster input=ndvi_andres maps=g.list raster pattern=prueba_andres* separator=comma
Gathering map information…
100%
Registering maps in the temporal database…
Registering maps in the space time dataset…
Updating space time dataset…
100%
all fine…
Is there anything special with those maps you use, i.e: which processing have they gone through?
Maybe you could put them in a dropbox and share so someone else can access them and test
Vero
2017-03-12 12:01 GMT+01:00 Andres Solarte <e.andres.solartec@gmail.com>:
Hello Markus
Regards
grass-user mailing list
grass-user@lists.osgeo.org
in range(128)
Just wondering:
Best
Hello Vero
Thank you for your answer, I’m glad to be here too!
I followed your steps and I have the same problem
GRASS 7.3.svn (prueba):~ > for i in seq 1 5
100%
100%
100%
100%
100%
GRASS 7.3.svn (prueba):~ > t.create type=strds temporaltype=absolute output=ndvi_andres title=“NDVI prueba” description=“prueba tesis” semantictype=mean
GRASS 7.3.svn (prueba):~ > t.register -i type=raster input=ndvi_andres maps=g.list raster pattern=prueba_andres* separator=comma
in range(128)
The dataset is available in the link below. The images were resampled but I think that’s not the problem :S
https://drive.google.com/open?id=0B5vy4w_s2kxmNXhnY0doYzQtN0E
Once again, thanks for your answer
Andrés.
2017-03-15 4:49 GMT-03:00 Veronica Andreo <veroandreo@gmail.com>:
Hola Andres!
Here are my steps:
for i in seq 1 5
100%
100%
100%
100%
100%
100%
100%
all fine…
Vero
Hello Markus
Regards
in range(128)
Just wondering:
Best
Hola Andres,
I just tested with your data…
No issues here. As you say, it must be something else… but I have no hint… I’m sorry
Hope someone else can point you to a solution
un beso,
Vero
2017-03-15 12:59 GMT+01:00 Andres Solarte <e.andres.solartec@gmail.com>:
Hello Vero
100%
100%
100%
100%
100%
in range(128)
Andrés.
Hola Andres!
Here are my steps:
for i in seq 1 5
100%
100%
100%
100%
100%
100%
100%
all fine…
Vero
Hello Markus
Regards
in range(128)
Just wondering:
Best
On Wed, Mar 15, 2017 at 12:59 PM, Andres Solarte
maps=`g.list raster pattern=prueba_andres* separator=comma`
start="2015-09-07" increment="1 days"
in range(128)
two suggestions:
1. switch on the fly to English in the session, then run the last command again:
export LANG=en_US
export LANGUAGE=en_US
export LC_MESSAGES=en_US
t.register ...
2. if that also fails, change the debug level with
g.gisenv set=DEBUG=1 # or 2 or 3 ...
t.register ...
g.gisenv set=DEBUG=0
and see if you can find out from the output where it roughly happens.
best
Hello Markus,
the first suggestion solved the problem
thank you so much, now it works
Gracias Vero también a vos!!!
Andrés.
2017-03-17 16:37 GMT-03:00 Markus Neteler <neteler@osgeo.org>:
in range(128)
two suggestions:
- switch on the fly to English in the session, then run the last command again:
export LANG=en_US
t.register …
- if that also fails, change the debug level with
g.gisenv set=DEBUG=1 # or 2 or 3 …
t.register …
best
Le Sat, 18 Mar 2017 11:53:48 -0300,
Andres Solarte <e.andres.solartec@gmail.com> a écrit :
Hello Markus,
This sounds like there might be some issue handling the translation.
Probably warrants a bug report.
Moritz
Andrés.
> Hi,
> > input=ndvi_andres maps=`g.list raster pattern=prueba_andres*
> > separator=comma` start="2015-09-07" increment="1 days"
> > <,25,26,ordinal not in range(128)
> two suggestions:
> command again:
> export LANG=en_US
> t.register ...
> t.register ...
> happens.
> best
> Markus
[Please keep discussions on the list]
Le Sun, 19 Mar 2017 19:27:28 -0300,
Luiz Andrade <lcoandrade@gmail.com> a écrit :
Well, normally this is a problem when GRASS finds special characters
(e.g. á, é, à, ã, etc). Check your strings for those characters and
remove them.
The problem here does not seem to be with file or path names as
everything works when the locale is set to en_US.
So there seems to be an issue when a different locale is used. This is
not something the user can handle, but is in the code.
Moritz
Luiz Claudio
> Em 19 de mar de 2017, à(s) 09:42, Moritz Lennert
> <mlennert@club.worldonline.be> escreveu:
>> Hello Markus,
> Moritz
>> Regards,
>> Andrés.
>>> Hi,
>>> two suggestions:
>>> command again:
>>> export LANG=en_US
>>> t.register ...
>>> t.register ...
>>> happens.
>>> best
>>> Markus
On Mon, Mar 20, 2017 at 11:12 AM, Moritz Lennert
remove them.
It would really help if you could change the debug level with
and then run
t.register ...
to see in the output where the problem roughly happens.
To switch back to "debug silence", run then:
Ok, but I changed the language on ubuntu. It solved the problem.
Enviado desde mi smartphone BlackBerry 10.
Mensaje original
De: Markus Neteler
Enviado: lunes, 20 de marzo de 2017 23:24
Para: Moritz Lennert
CC: grass-user@lists.osgeo.org
Asunto: Re: [GRASS-user] GRASS, ordinal not in range(128)
remove them.
and then run
t.register ...
Le 21 mars 2017 04:38:11 GMT+01:00, Andres Solarte <e.andres.solartec@gmail.com> a écrit :
Yes. Could you change it back to what it was and then run the command in debug mode as suggested by Markus ?
Moritz
Mensaje original
De: Markus Neteler
remove them.
is
and then run
t.register ...
Hello,
I changed the debug level as Markus suggested
this is the result
t.register -i type=raster input=ndvi_andres maps=g.list raster pattern=MODIS* separator=comma
D1/1: G_set_program_name(): g.list
D1/1: G_set_program_name(): t.register
D1/1: G_set_program_name(): g.gisenv
D1/1: grass.script.core.start_command(): t.connect -c
D1/1: G_set_program_name(): t.connect
D1/1: grass.script.core.start_command(): g.gisenv -n
D1/1: Start messenger server
D1/1: Initiate the temporal database
D1/1: Start C-interface server
D1/1: Checking mapset
D1/1: c_library_server._available_mapsets:
mapset: prueba
has permission 1
in search path: 1
mapset: PERMANENT
has permission 1
in search path: 1
D1/1: get_available_temporal_mapsets:
mapset prueba
driver sqlite
database /home/andres/Escritorio/PRUEBAQGIS/Prueba/prueba/tgis/sqlite.db
mapset PERMANENT
driver None
database None
D1/1: DBConnection constructor:
backend: sqlite
dbstring: /home/andres/Escritorio/PRUEBAQGIS/Prueba/prueba/tgis/sqlite.db
mapset: prueba
has permission 1
in search path: 1
mapset: PERMANENT
has permission 1
in search path: 1
mapset prueba
driver sqlite
mapset PERMANENT
driver None
database None
backend: sqlite
D1/1: G_find_raster(): name=MODIS_2015250_h12v12_1km_NDVI mapset=prueba
D1/1: G_find_raster2(): name=MODIS_2015250_h12v12_1km_NDVI mapset=prueba
D1/1: grass.script.core.start_command(): g.message -e message=ascii,Definir tiempo absoluto válido para mapa <,25,26,ordinal not in range(128)
D1/1: G_set_program_name(): g.message
in range(128)
D1/1: Stop messenger server
Regards
Andrés.
2017-03-21 5:22 GMT-03:00 Moritz Lennert <mlennert@club.worldonline.be>:
Moritz
Mensaje original
De: Markus Neteler
remove them.
is
and then run
t.register …
To switch back to “debug silence”, run then:
On Tue, Mar 21, 2017 at 3:13 PM, Andres Solarte
Hello,
this is the result
good, we are getting closer...:
t.register -i type=raster input=ndvi_andres maps=`g.list raster
pattern=MODIS* separator=comma` start="2015-09-07" increment="1 days"
in range(128)
In the locale/po/grasslibs_es.po file there is the mention of the
corresponding source code lines:
#: ../lib/python/temporal/register.py:422
#, python-format
msgid ""
"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
"%(end)s"
msgstr ""
"Definir tiempo absoluto válido para mapa <%(id)s> con capa %(layer)s en "
"%(start)s - %(end)s"
#: ../lib/python/temporal/register.py:427
#, python-format
msgid "Set absolute valid time for map <%s> to %s - %s"
msgstr "Definir tiempo absoluto válido para mapa <%s> en %s - %s"
Probably a Python issue there in reading the "á" of "válido"?
Hello,
I’m working with grass72, I modified the /usr/lib/grass72/locale/es/LC_MESSAGES/grasslibs.mo file by deleting the accents and it works, so, maybe is a Python issue as you say.
2017-03-21 18:05 GMT-03:00 Markus Neteler <neteler@osgeo.org>:
Hello,
this is the result
good, we are getting closer…:
in range(128)
#: …/lib/python/temporal/register.py:422
#, python-format
msgid “”
“%(end)s”
msgstr “”
“%(start)s - %(end)s”
#: …/lib/python/temporal/register.py:427
#, python-format
msgid “Set absolute valid time for map <%s> to %s - %s”
msgstr “Definir tiempo absoluto válido para mapa <%s> en %s - %s”
Probably a Python issue there in reading the “á” of “válido”?
Hello,
I made two changes for this issue.
- In the file …etc/python/grass/temporal/register.py (line 422 for me), I added the marked in red
else:
msgr.debug(1, _((“Set absolute valid time for map <%s> to %s - %s”)
% (map.get_map_id(), str(start_time), str(end_time))).encode(‘utf8’))
There is a similar issue after that, so I added the marked in red in the file
…etc/python/grass/temporal/abstract_space_time_dataset.py (line 2282)
self.msgr.verbose(_((“Update metadata, spatial and temporal extent from”
" all registered maps of <%s>") % (self.get_id())).encode(‘utf8’))
Now, I don’t have problems with accents
t.info input=ndvi_andres@regresion
±------------------- Space Time Raster Dataset -----------------------------+
±------------------- Basic information -------------------------------------+
Id: … ndvi_andres@regresion
Name: … ndvi_andres
Mapset: … regresion
Creator: … andres
Temporal type: … absolute
Creation time: … 2017-03-22 15:58:33.237769
Modification time:… 2017-03-22 15:58:40.516887
Semantic type:… mean
±------------------- Absolute time -----------------------------------------+
Start time:… 2015-09-07 00:00:00
End time:… 2015-09-12 00:00:00
Granularity:… 1 day
Temporal type of maps:… interval
±------------------- Spatial extent ----------------------------------------+
North:… 1.0
South:… -41.0
East:… … 1.6756
West:… -78.3244
Top:… 0.0
Bottom:… 0.0
±------------------- Metadata information ----------------------------------+
2017-03-22 14:47 GMT-03:00 Andres Solarte <e.andres.solartec@gmail.com>:
Hello,
Hello,
this is the result
in range(128)
#, python-format
msgid “”
“%(end)s”
msgstr “”
#, python-format
On Wed, Mar 22, 2017 at 8:21 PM, Andres Solarte
Hello,
1. In the file ...etc/python/grass/temporal/register.py (line 422 for me), I
else:
msgr.debug(1, _(("Set absolute valid time for map <%s> to %s - %s")
str(end_time))).encode('utf8'))
well, msgr.debug() should not have the _() macro at all.
Debug should not go into translations.
file
...etc/python/grass/temporal/abstract_space_time_dataset.py (line 2282)
self.msgr.verbose(_(("Update metadata, spatial and temporal extent from"
(self.get_id())).encode('utf8'))
.. this one is of course eligible.
Now, I don't have problems with accents
Thanks for checking!
To be fixed by our Python gurus in SVN
Hello,
I just discover this thread. It seems to be the same issue I've
reported two months ago:
https://trac.osgeo.org/grass/ticket/3338
Best regards,
Laurent
2017-03-22 16:44 GMT-06:00 Markus Neteler <neteler@osgeo.org>:
Hello,
else:
file
