I'm trying to install GRASS 64bit using the osgeo64bit installer but the installed
GRASS 6.4.3 is not working properly ang gives an error,
something like:
g.mapset.exe has stop working
then the interface seems to start but i cannot load any raster data
as the interface to dislpay raster does not show up:
On Thu, Nov 20, 2014 at 6:16 AM, Roy <royroge@outlook.com> wrote:
installed
something like:
d.rast.exe has stop working
any idea on how to solve this ?
I'm not sure what is the situation now but 64bit OSGeo4W was experimental.
The stable version was only 32bit. You should be able to find more on
OSGeo4W website [1] or mailing list [2]. Let us know you progress.
FYI, you email was unfortunately marked as spam by Gmail.
I’m trying to install GRASS 64bit using the osgeo64bit installer but the installed
something like:
I’m not sure what is the situation now but 64bit OSGeo4W was experimental. The stable version was only 32bit. You should be able to find more on OSGeo4W website [1] or mailing list [2]. Let us know you progress.
Was experimental. It is just as stable as 32 bit now, just doesn't have
100% coverage of all the same packages (I think some web stuff is still
not 64bit). GRASS should be working. If it is not the place to report it
is the osgeo4w mailing list or the issue tracker https://trac.osgeo.org/osgeo4w
Note, you can easily install both 32 and 64 bit on the same machine just
put them in different root folders.
Alex
On 11/20/2014 06:34 AM, Roy wrote:
Hi Vaclav,
thanks for you answer, i'll check on OSgeo4W site
<mailto:royroge@outlook.com>> wrote:
but the installed
something like:
progress.
I have installed the newest osgeo4w 64-bit with GRASS 6.4.3-5, and it's
still not working properly, returning "g.mapset.exe has stop working" and
"d.rast.exe has stop working" as our friend reported.
