Dear All,
I face difficulty in rendering the raster data in grass data sets. Though I can directly import an image into qgis, it renders nice. But, with grass plugins it is not happening. I am on Fedora 14 x86_64 platform.
regards,
Ambrish
On Sun, Nov 21, 2010 at 4:26 PM, ambrish dhaka <ambijat@hotmail.com> wrote:
Dear All,
To my knowledge Fedora still serves GRASS 6.3 (but they started to
produce 6.4 RPMs these days).
Which version do you run? From Fedora or selfcompiled?
Thanks! Markus,
I found that gdal rpms are installed and the manage plugins windows also shows gdal tools therefore, this doesn’t seem to be an issue. Also, when I try to select the project properties into UTM the workspace still remains on xy coordinate.
Ambrish
Date: Mon, 22 Nov 2010 08:41:04 +0100
Subject: Re: [GRASS-user] grass plugin fail to render
To: ambijat@hotmail.comHi Ambrish,
(it would be better to keep this on the list to enable other to learn
or help)moving stuff to a different Linux distro should not be an issue.
But did you install the GDAL-GRASS plugin?Also: what is really the error message?
On Mon, Nov 22, 2010 at 4:27 AM, ambrish dhaka ambijat@hotmail.com wrote:
Hi! Markus,
It is the Grass 6.3 version and they are coming with the standard
installation repo.
But, real problem is that in standalone Grass the thing works fine. Or even
fetching them into Qgis is also good, but the opening raster from dataset in
Qgis is creating trouble.
One thing I did not mention is that I am moving this database from one
partition to another as I had previously created this dataset in Opensuse,
then I took it to a window partition and then after having Fedora 14
installed I brought this database back into home folder. Is that a possible
reason for this mess?Thanks!
AmbrishFrom: neteler@osgeo.org
Date: Sun, 21 Nov 2010 23:08:47 +0100
CC: grass-user@lists.osgeo.org; qgis-user@lists.osgeo.orgOn Sun, Nov 21, 2010 at 4:26 PM, ambrish dhaka ambijat@hotmail.com
wrote:Dear All,
Though I
plugins it is not happening. I am on Fedora 14 x86_64 platform.To my knowledge Fedora still serves GRASS 6.3 (but they started to
produce 6.4 RPMs these days).Which version do you run? From Fedora or selfcompiled?
