what is the simplest way to get GRASS connected to a PostgreSQL database? I have built a postgres database and created a table.
I suspect that i have two problems:
my pg_hba.conf file (or not starting postmaster with -i flag? it is currently started from an init.d script, but i thought i located where in that startup script file postmaster is fired up and have tried -i)
my command line connection may be faulty.
my pg_hba.conf file for host has “host all all 192.168.0.0/16 trust”
my connection attempt via GRASS is: v.db.connect -o map=sites driver=pg database=“host=localhost,dbname=sites” table=distances
which yeilds the following error:
DBMI-Postgres driver error:
Cannot connect to Postgres: FATAL: missing or erroneous pg_hba.conf file.
1) my pg_hba.conf file (or not starting postmaster with -i flag? it is
2) my command line connection may be faulty.
my pg_hba.conf file for host has "host all all 192.168.0.0/16 trust"
database="host=localhost,dbname=sites" table=distances
