there is something strange with GRASS prompt on my computer (Debian
GNU/Linux unstable, UTF8). An example script:
for map in $(ls *.xml); do echo "$map -> ${map%%.xml}"; done
GRASS not running
$ for ...
abscl-seidl.gkf.xml -> abscl-seidl.gkf
abscl-temelin.gkf.xml -> abscl-temelin.gkf
bug-1.3.25-zpk.gkf.xml -> bug-1.3.25-zpk.gkf
zoltan-test_2d_gon.gkf.xml -> zoltan-test_2d_gon.gkf
zoltan-test_3d_dms.gkf.xml -> zoltan-test_3d_dms.gkf
zoltan-test_3d_gon.gkf.xml -> zoltan-test_3d_gon.gkf
-> OK
GRASS running ...
GRASS > for ...
abscl-seidl.gkf.xml -> abscl-seidl.gkf.xml
abscl-temelin.gkf.xml -> abscl-temelin.gkf.xml
bug-1.3.25-zpk.gkf.xml -> bug-1.3.25-zpk.gkf.xml
zoltan-test_2d_gon.gkf.xml -> zoltan-test_2d_gon.gkf.xml
zoltan-test_3d_dms.gkf.xml -> zoltan-test_3d_dms.gkf.xml
zoltan-test_3d_gon.gkf.xml -> zoltan-test_3d_gon.gkf.xml
So, ${map%%.xml} does not work any more, overmore there is a strange
last line containing empty variable $map.
Am I doing anything wrong? I am a little bit confused;-)
Best,
Martin
H_B
May 15, 2006, 3:33am
2
I don't know why that isn't working, but for the same thing you might
try:
echo "$map -> `basename $map .xml`"
Hamish
Why the "ls", rarther than just:
for map in *.xml ; do ...
GRASS not running
$ for ...
-> OK
GRASS running ...
GRASS > for ...
My first suspicion would be that the session startup is changing
either which "ls" command is used or the behaviour of the "ls"
command. Everything except for "ls" is a shell built-in.
