Yes, the idea is just for script editing, but to run the script I will do within grass GUI.
I will also setup PYTHONPATH as you suggested
2014/1/18 Vaclav Petras <wenzeslaus@gmail.com>
Miltinho - mcr@rc.unesp.br
Laboratório de Ecologia Espacial e Conservação - LEEC
Depto de Ecologia - UNESP - Rio Claro
Av. 24A, 1515- Bela Vista
13506-900 Rio Claro, SP, Brasil
Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
Cel: 19 9853-3220 / 19 9853-5430
Depto Ecologia http://ib.rc.unesp.br/#!/departamentos/ecologia/
PG ECO & BIODIV http://ib.rc.unesp.br/#!/departamentos/ecologia/pos-graduacao-em-ecologia-e-biodiversidade/
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
On Sat, Jan 18, 2014 at 6:47 PM, Milton Ribeiro <miltinho.astronauta@gmail.com> wrote:
Hi there
Just to keep the info, I found it, and now everything is working fine with autocomplete under Wingware.
I copied the folder “C:\Program Files (x86)\GRASS GIS 6.4.3RC2\etc\python\grass” to
“C:\Python27\Lib\site-packages”
Thanks for info. Just keep in mind that what you did is not a clean way, although it will probably work for completion and docstrings. However, remember that still you should run scripts from the GRASS session (GUI or command line) and not directly from the editor.
Anyway, setting PYTHONPATH to C:\Program Files (x86)\GRASS GIS 6.4.3RC2\etc\python\grass for your editor should work and it strange if it do not. But this can be editor/IDE dependent.
Thanks again
milton
2014/1/18 Milton Ribeiro <miltinho.astronauta@gmail.com>
Dear Anna and Vaclav,
thanks a lot for your kind reply.
I tried to find grass.script to define de proper address where it is, or to copy this to my python/lib directory but I could’nt find.
I am using window 8.
Any hint are welcome.
best
milton
2014/1/17 Vaclav Petras <wenzeslaus@gmail.com>
On Fri, Jan 17, 2014 at 2:23 PM, Milton Ribeiro <miltinho.astronauta@gmail.com> wrote:
Dear all,
I would like to know if is there anyone using
WingIDE python editor to write python grass scripting.
I am using WingIDE under windows, but grass.scripting lib methods not autocomplete, and the help of grass.scripting not appears on WingIDE as for other libs of python.
I’m not using WingIDE nor Windows, so I hope somebody else will reply, too.
However, (for several reasons) grass.script is not installed to the system (to the python installation), so you need to tell your IDE where to look for the grass.scripting. One possibility is to set PYTHONPATH environmental variable (which will then appear in sys.path in python) for the IDE:
http://www.wingware.com/doc/intro/tutorial-python-path
Maybe there is some settings even directly in the editor. The path should be set to the directory where grass.script, i.e. something like:
C:\path\to\grass\etc\python\
The way which works the best for me, on Ubuntu with Spyder Python IDE, is starting the editor from within the GRASS session (GRASS command line). This ensures that the environment is set right and you not only have the autocomplete and documentation but also that you can run your python GRASS scripts in the IDE. In theory, this should work the same on MS Windows.
Vaclav
best wishes
grass-user mailing list
grass-user@lists.osgeo.org
