[GRASS-user] Grass, Python, mapcalc
Here I am again with some questions :wink:
I’m now trying to use r.sun and r.mapcalc with Python to create my annual solar radiation map.
I’m using the Python shell inside GRASS.
For testing purposes I start with 9 days.
The r.sun part seems to be working:
for x in range(1, 10, 1):
print “Working on day %d” % (x)
glob_rad = ‘global’ + str(x)
grass.run_command(‘r.sun’, flags = ‘s’, elevin = ‘w001001@temp’, aspin = ‘aspect@temp’, slopein = ‘slope@temp’, glob_rad = glob_rad, day = x)
I do have a question about parsing the --overwrite flag. How to do that. Adding flags=‘s, --overwrite’ or flags=‘s, -overwrite’ gives a compile error.
Now I try to combine the results of r.sun into 1 raster.
This is working:
if x == 2:
exp = ‘sun = global1@temp + global2@temp’
print exp
grass.mapcalc(exp, quiet=False, verbose=False, overwrite=True)
This is also working:
if x == 2:
print exp
elif x > 2:
exp = ‘sun = sun@temp + global’ + str(x) + ‘@temp
print exp
and produces this output:
sun = sun@temp + global3@temp
sun = sun@temp + global4@temp
sun = sun@temp + global5@temp
sun = sun@temp + global6@temp
sun = sun@temp + global7@temp
sun = sun@temp + global8@temp
sun = sun@temp + global9@temp
But when I execute this using
Grass crashes completely.
Has this something to do with having the output file is the input file as well?
If this is not allowed how can I combine all output files from r.sun into 1 raster?
Paul
could you provide a source file to check?
This is working:
if x == 2:
print exp
if x == 2:
print exp
elif x > 2:
print exp
Paul
grass-user mailing list
grass-user@lists.osgeo.org
Rashad
Hi there,
I believe you overwrite by setting:
flags=“s, o”
This is working:
if x == 2:
print exp
if x == 2:
print exp
elif x > 2:
print exp
GRASS doesn’t care what you’re combining, when you use the map calculator it just sees numbers so that shouldn’t be a problem.
I don’t know why the map calculator to overwrite the input map would be a problem either. I’m not familiar with your syntax though. What happens when you just enter the expression on the “normal” command line?
r.mapcalc “sun = sun + global3”
That should work.
Best,
Daniel
Thanks again Daniel for your help.
When I do the calculation in the GUI instead of in the Python shell I get these results:
r.mapcalc sun = global1@temp+ global2@temp
(Fri Dec 28 12:26:10 2012) Command finished (1 sec)
r.mapcalc sun = sun@temp+ global3@temp
ERROR: Unable to close raster map
When I Google on the error message I find this post from 2010 http://lists.osgeo.org/pipermail/grass-user/2010-October/058463.html saying:
><i> Why am I obtaining this error? and How can I avoid it?
</i>
Because you're using the same map as both input and output, which
won't work. Either use a temporary name for the intermediate map, or
replace the second grass.mapcalc call with r.null.
I’ll have a look in using a temp file. This will make my script more complicated :wink:
Paul
Paul Meems
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
2012/12/28 Daniel Lee <lee@isi-solutions.org>
Hi there,
flags=“s, o”
This is working:
if x == 2:
print exp
if x == 2:
print exp
elif x > 2:
print exp
That should work.
Best,
Daniel
Hmm, okay. That post is pretty old though and there have been a lot of improvements to GRASS since. I don’t think it applies any more. Check this out:
GRASS 6.4.3svn (EPSG25832_UTM32N):~ > r.mapcalc test=1
100%
GRASS 6.4.3svn (EPSG25832_UTM32N):~ > r.mapcalc test=test+3
100%
GRASS 6.4.3svn (EPSG25832_UTM32N):~ > r.mapcalc “test = test + 3”
100%
This worked for me. Make sure that you don’t forget to use quote marks if you have spaces in the middle of your expression. I think that’s your problem.
Daniel
2012/12/28 Paul Meems <bontepaarden@gmail.com>
</i>
Paul
Paul Meems
www.mapwindow.org
www.mapwindow.nl
Hi there,
flags=“s, o”
This is working:
if x == 2:
print exp
if x == 2:
print exp
elif x > 2:
print exp
That should work.
Best,
Daniel
Thanks Daniel,
I'm using the Windows version of 6.4.3RC2, downloaded the installer.
When I use your example I get this result:
(Fri Dec 28 13:03:32
2012)
r.mapcalc
test=1
(Fri Dec 28 13:03:34 2012) Command finished (2
sec)
(Fri Dec 28 13:03:51
2012)
r.mapcalc
test=test+3
(Fri Dec 28 13:03:53 2012) Command finished (2 sec)
I'm running the commands in the Command Console of GRASS.
I also don't get the 100% response.
I can try to download the nightly build, but my current version is just 8
days older.
Has there been so much changes in these 8 days?
Paul
u
To my experience with r.mapcalc you cannot do what yo do with
programming languages... e.g. i=i+1 will not work directly. Instead you
could try a more indirect way, something like (here is an example with
bash shell script):
#g.mremove rast=out* (to remove previous stuff, if needed)
r.mapcalc sun=global1
for a in ‘seq 2 10‘; do
r.mapcalc out = sun + global$a
g.rename --o rast=out,sun
done
basically the main idea is to use an intermediate map and then before
the loop ends, pass it (with g.rename) to the map variable you want.
There might be a more elegant way with python, but hopefully this shell
script example might help you.
HTH,
sotiris
get these results:
saying:
>/ Why am I obtaining this error? and How can I avoid it?
I'll have a look in using a temp file. This will make my script more
complicated :wink:
Paul
*Paul Meems *
www.mapwindow.org <http://www.mapwindow.org/&gt;
www.mapwindow.nl <http://www.mapwindow.nl/&gt;
<mailto:lee@isi-solutions.org>>
    Hi there,
        I'm now trying to use r.sun and r.mapcalc with Python to
        I'm using the Python shell inside GRASS.
        print "Working on day %d" % (x)
        glob_rad = 'global' + str(x)
        grass.run_command('r.sun', flags = 's', elevin =
        'w001001@temp', aspin = 'aspect@temp', slopein = 'slope@temp',
        to do that. Adding flags='s, --overwrite' or flags='s,
        -overwrite' gives a compile error.
    flags="s, o"
        This is working:
        if x == 2:
        exp = 'sun = global1@temp + global2@temp'
        print exp
        if x == 2:
        print exp
        elif x > 2:
        exp = 'sun = sun@temp + global' + str(x) + '@temp'
        print exp
        input file as well?
    GRASS doesn't care what you're combining, when you use the map
    calculator it just sees numbers so that shouldn't be a problem.
    I don't know why the map calculator to overwrite the input map
    would be a problem either. I'm not familiar with your syntax
    "normal" command line?
    r.mapcalc "sun = sun + global3"
    That should work.
    Best,
    Daniel
Daniel's example works for me as well (also GRASS 6.4.3svn, and more
that 10 days old, I am on linux though).
thanks for the update!
sotiris
On 12/28/2012 02:11 PM, Paul Meems wrote:
Thanks Daniel,
2012)
r.mapcalc
test=1
sec)
2012)
r.mapcalc
test=test+3
just 8 days older.
Paul
    u
I may be off base with what you want, but it seems like may you want to use GRASS r.series, namely…
base=$(basename $input .grib2)
r.series input=“g.mlist rast pattern=${base} .* sep=,” output=${base".total method=sum --overwrite
So, if you have a bunch of .grib2 files, for instance, that have been read into GRASS that you want to sum; these GRASS raster maps all have the same base filename root, $base.
From the GRASS manual:
r.series makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers. Following methods are available:- average: average value
  • count: count of non-NULL cells
  • median: median value
  • mode: most frequently occuring value
  • minimum: lowest value
  • maximum: highest value
  • range: range of values (max - min)
  • stddev: standard deviation
  • sum: sum of values
  • variance: statistical variance
  • diversity: number of different values
  • slope: linear regression slope
  • offset: linear regression offset
  • detcoeff: linear regression coefficient of determination
  • min_raster: raster map number with the minimum time-series value
  • max_raster: raster map number with the maximum time-series value
I hope this helps…
Tom
On Fri, Dec 28, 2012 at 7:36 AM, S. Koukoulas (lists) <sotkouklistes@gmail.com> wrote:
programming languages… e.g. i=i+1 will not work directly. Instead you
bash shell script):
done
HTH,
sotiris
get these results:
saying:
Because you’re using the same map as both input and output, which
won’t work. Either use a temporary name for the intermediate map, or
complicated :wink:
Paul
*Paul Meems *
www.mapwindow.org <http://www.mapwindow.org/>
www.mapwindow.nl <http://www.mapwindow.nl/>
mailto:[lee@isi-solutions.org](mailto:lee@isi-solutions.org)>
Hi there,
flags=“s, o”
This is working:
if x == 2:
print exp
if x == 2:
print exp
elif x > 2:
print exp
input file as well?
That should work.
Best,
Daniel
Thomas E Adams
Development & Operations Hydrologist
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
[http://www.erh.noaa.gov/er/ohrfc/](http://www.erh.noaa.gov/er/ohrfc/)
EMAIL:	[thomas.adams@noaa.gov](mailto:thomas.adams@noaa.gov)
VOICE:	937-383-0528
FAX:	937-383-0033
it's an OS feature. in the windows operating system, an opened file can't be
overwritten, thus this error.
AFAIK don't rely that this always works correctly in linux.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/Grass-Python-mapcalc-tp5024847p5024917.html
