[GRASS-user] GRASS Python Script- How to check if the imported file is a raster
Greetings
I've built a python script to import a certain type of data (Globcover products) through r.in.gdal and gdalwarp. But for instance, in the other day I selected a non-raster file (txt) and:
- it checked that it exists (check_file= os.path.isfile(input)
but since gdalwarp and r.in.gdal does not recognize as a raster it gave an error but I want to "STOP" the process... any suggestion?
And by the way, how can I eliminate the text-outputs from gdalwarp
This is related also with what people have been discussing but I'm running python scripts in WinGRASS 6.4 (through OSGEO4W). And it seems to be working :slight_smile:
Thanks
Antonio
