Markus Neteler wrote:
do you have the GRASS stand-alone installed as well?
Might it be that some DLLs conflict (or Python)?
FWIW I've got both installed here on a laptop without any cross-over
problems at all.
Hamish
problems at all.
Hamish
Dear all,
I have worked with Native Windows Stand-Alone (6.3) and OSGeo4W/MSYS/compilede 6.4R4 without problem on my Windows Vista 64bits. But two days ago I decided to “JUST” install QGIS, and after that nothing works for me ;-(
I can’t run 6.3 properly (as I not have cygwin running properly); 6.4 start to open a lot of windows, and after close all them without no error message; I removed 10x the C:\OSGeoW4, and tryed to follow
http://trac.osgeo.org/grass/wiki/CompileOnWindows
But everytime I get the same issue, when I try open Msys,
a lot a windows open recursively, and at the end, nothing happens.
Anu help are welcome.
milton
2009/5/15 Hamish <hamish_b@yahoo.com>
Might it be that some DLLs conflict (or Python)?FWIW I’ve got both installed here on a laptop without any cross-over
problems at all.Hamish
Dear all,
Just to inform that it is a know issue on VISTA 64, and a discussion can be found at
http://forums.mozillazine.org/viewtopic.php?f=42&t=759325
and the bugfix (on my case) can be found at
http://downloads.sourceforge.net/mingw/MSYS-1.0.11-20070729.tar.bz2
Remembering that it only occurred when after have MSYS and GRASS installed and running I decided to install QGIS from OSGeoW4. May be during the QGIS intallation process automatically I got my MSYS updated for some version that not run perfectly on Vista64.
I suggest you put a note for new Vista 64 users.
Bests
milton
2009/5/15 Milton Cezar Ribeiro <miltinho.astronauta@gmail.com>
Dear all,
http://trac.osgeo.org/grass/wiki/CompileOnWindowsBut everytime I get the same issue, when I try open Msys,
a lot a windows open recursively, and at the end, nothing happens.Anu help are welcome.
milton2009/5/15 Hamish <hamish_b@yahoo.com>
On Sun, May 17, 2009 at 7:06 AM, Milton Cezar Ribeiro
<miltinho.astronauta@gmail.com> wrote:
Dear all,
found athttp://forums.mozillazine.org/viewtopic.php?f=42&t=759325
http://downloads.sourceforge.net/mingw/MSYS-1.0.11-20070729.tar.bz2Remembering that it only occurred when after have MSYS and GRASS installed
done:
http://trac.osgeo.org/grass/wiki/CompileOnWindows#InstalltheenvironmentforcompilationMingW
