[GRASS-user] GRASS raster curvature analysis type
Hello,
I would like to know whether raster curvature analysis in GRASS is Gaussian
or Mean curvature analysis?
https://en.wikipedia.org/wiki/Gaussian_curvature
https://en.wikipedia.org/wiki/Mean_curvature
This GRASS 7.2 manuals page mentions that raster curvature analysis can be conducted in direction of steepest slope and in the direction of the contour tangent, therefor distinguishing two curvature options: profile and tangential.
Still are these two Gaussian or Mean curvatures?
Thank you for the reply.
Kind regards,
Djordje Spasic
georges wrote
Hello,
is Gaussianor Mean curvature analysis?
and tangential.
I can't tell you directly which algorithm is used.
fortunately GRASS GIS is open source; so maybe have a look at the source
code to check:
r.slope.aspect:
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.slope.aspect/main.c
or
r.resamp.rst
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.resamp.rst/main.c
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-raster-curvature-analysis-type-tp5285498p5285523.html
On Tue, Sep 13, 2016 at 7:58 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
georges wrote
Hello,
and tangential.
code to check:
r.slope.aspect:
or
r.resamp.rst
HTH
also r.param.scale:
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.param.scale/
best regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
On Tue, Sep 13, 2016 at 4:02 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
georges wrote
Hello,
and tangential.
code to check:
r.slope.aspect:
or
r.resamp.rst
HTH
also r.param.scale:
You find the formulas used for the r.slope.aspect and r.resamp.rst
implementations in the GRASS book, 3rd edition, 2008, Springer,
Appendix pages 371-376.
Best,
georges wrote
Hello,
and tangential.
code to check:
r.slope.aspect:
or
r.resamp.rst
HTH
also r.param.scale:
IIUC, Gaussian and Mean curvatures are based on principal curvatures.
Principal curvatures in turn are calculated for an orthonormal basis.
r.param.scale calculates different principal curvatures for different
bases (z-axis and the surface normal vector). You can obtain Gaussian
or Mean curvatures from these principal curvatures.
Markus M
Best,
Dear Mrs. Patrasova, Mr. Metz, Mr. Kudrnovsky, Mr. Neteler,
Thank you all for the replies!!
@ Mr. Metz:
So curvature analysis in GRASS are neither Gaussian nor Mean curvature analysis types? Did I understand that correctly?
@ Mr. Kudrnovsky, Mrs. Patrasova:
Both source codes seem to mention the profile and tangential curvature.
@Mr. Neteler:
The book is a bit expensive (for my country) but seems to be quite good as well!
I also not sure just looking at the equations would help me identify whether it is Gaussian or Mean curvature type, due to my non-mathematical non-GIS background.
Kind regards,
Djordje Spasic
On Wed, Sep 14, 2016 at 1:07 AM, Djordje Spasic <issworld2000@yahoo.com> wrote:
@ Mr. Metz:
You can do both in GRASS. Get the principal curvatures you need with
one of the previously mentioned modules, then calculate Gaussian (K1 *
K2) and/or Mean ((K1 + K2) / 2) curvature.
Markus M
@Mr. Neteler:
well!
background.
Kind regards,
Djordje Spasic
Dear Mr. Metz,
Thank you for the useful reply.
I now understand that one can perform Gaussian and Mean curvature analysis in GRASS, thanks to you.
But neither profile nor tangential GRASS curvatures are Gaussian nor Mean curvatures?
Kind regards,
Djordje Spasic
On Wed, Sep 14, 2016 at 9:20 AM, Markus Metz
@ Mr. Metz:
Related FWD from Helena, supporting above:
On Wed, Sep 14, 2016 at 1:08 AM, Helena Mitasova <hmitaso@ncsu.edu> wrote:
No it is neither gaussian, nor mean. v. surf.rst outputs also mean. But any
curvature can be computed using the second order derivatives output and map
algebra. It would be also relatively easy to add mean and gaussian curvature
to the outputs.
Helena
Dear Mr. Neteler,
Thank you for the help.
