[GRASS-user] grass rastercal doesn't work
Hello everybody,
I have problems with r.mapcalc
I’m use a fresh compiled grass70 from source in my ubuntu desktop 12.10
the review cod of grass is 55939.
I 'm just trying to clip a raster using a mask:
first I created a mask from a raster, then I use r.mapcal:
new_cut_map=old_map
I got a normal conclusion of calculation with 100% done and the specification [Raster MASK present],
but the new raster layer seems to be void.
I think I have problems with gdal lib?
Have you some hints?
Regards
Eugenio
On 22/04/13 17:14, Eugenio Trumpy wrote:
Hello everybody,
I'm use a fresh compiled grass70 from source in my ubuntu desktop 12.10
new_cut_map=old_map
Check your region settings.
Moritz
Thank Moritz,
your hint partially solved my problem, because now
I got a map, but that is not clipped by the mask.
What could be the problem now?
Regards
Eugenio
Date: Mon, 22 Apr 2013 17:44:29 +0200
To: frippe12573@hotmail.com
CC: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] grass rastercal doesn’t work
Hello everybody,
new_cut_map=old_map
Moritz
On 22/04/13 17:58, Eugenio Trumpy wrote:
Thank Moritz,
Difficult to say without more info. Did you redefine your mask after changing the region settings ? Have you tried to display MASK to see if it is set correctly ?
Moritz
Regards
Eugenio
> From: mlennert@club.worldonline.be
> Subject: Re: [GRASS-user] grass rastercal doesn't work
> > Hello everybody,
> > new_cut_map=old_map
> Moritz
Hello Moritz,
I Tried just now to redefine the mask, and re-run the
r.mapcalc, but I got the sema result:
I have the new map but with the same size of the starting one,
again seems the mask doesn’t work…
Any other hints or test to do?
Regards
E.
Date: Tue, 23 Apr 2013 09:30:15 +0200
Thank Moritz,
Moritz
Regards
Eugenio
Hello everybody,
new_cut_map=old_map
Moritz
