When I launch GRASS, after selecting the mapset I get an error:
"Unable to get current geographic extent. Force quitting wxGUI..."
The error started after I tried to set the region using QGIS's region
setting gui.
So I guess the region has become corrupted.
Does anyone know where what file the region is set in? I.e. is there some
file I can delete to reset it.
I'm on GRASS 6.4.2, Windows 7 64-bit
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-region-corruption-tp4977148.html
Look for a file named WIND, in the given mapset.
I was about to point you to [1], then I noted that this page tells you the name of the default region (PERMANENT/DEFAULT_WIND), the location of saved regions (in a given mapset, under the windows directory) but doesn't tell you that WIND keeps the values of the current region.
Hermann
[1] http://grass.osgeo.org/grass64/manuals/html64_user/g.region.html
setting gui.
Try looking in a text file called "WIND" in your mapset directory.
It sets the region WINDow. There should be a DEFAULT_WIND file in that
location's PERMANENT mapset which you can use as a template to replace
the broken WIND file.
Hamish
ps- wouldn't hurt to file a bug with qgis either, with before & after versions of what it did to the WIND file.
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-region-corruption-tp4977148p4977206.html
