Sorry for forwarding this in the grass-user list. I must have
messed up somehow my grass-dev account or I don't know what... I can't
send anything to grass-dev(?).
Regards, Nikos
Regards, Nikos
Nikos,
this has been fixed recently in QGIS trunk.
On Mon, Nov 24, 2008 at 6:24 PM, Nikos Alexandris
send anything to grass-dev(?).Regards, Nikos
---------- Forwarded message ----------
From: Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
To: grass-dev@lists.osgeo.org
Date: Mon, 24 Nov 2008 07:49:10 +0100
Subject: grass-related failure when building qgis_0_11
Hi all! I get this error when building qgis 0.11 from source. I've read
the http://trac.osgeo.org/grass/ticket/364 ticket. Is it really fixed?This problem does not occur when building qgis preview version.
[ 71%] Building CXX object
src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o
/usr/local/grass-6.4.svn/include/grass/Vect.h: In static member function
'static int QgsGrassProvider::openMap(QString, QString, QString,
QString)':
/usr/local/grass-6.4.svn/include/grass/Vect.h:197: error: too many
arguments to function 'int Vect_build(Map_info*)'
/usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1040: error: at this point in file
/usr/local/grass-6.4.svn/include/grass/Vect.h: In member function 'bool
QgsGrassProvider::closeEdit(bool)':
/usr/local/grass-6.4.svn/include/grass/Vect.h:199: error: too many
arguments to function 'int Vect_build_partial(Map_info*, int)'
/usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1495: error: at this point in file
/usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1496: error: at this point in file
make[2]: ***
[src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o] Error
1
make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
make: *** [all] Error 2
------------------------------------------------------------------------Nikos
grass-user mailing list
grass-user@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
QString)':
make[2]: ***
1
I have backported the needed GRASS provider changes from QGIS-trunk
to 0.11.svn and sent to the QGIS people for integration.
> QString)':
> make[2]: ***
> 1
> ------------------------------------------------------------------------I have backported the needed GRASS provider changes from QGIS-trunk
to 0.11.svn and sent to the QGIS people for integration.Markus
Thanks to Markus it works now
Nikos
