[GRASS-user] grass run_command within python/grass script
Group,
I am running a grass-python script but when i replace a variable argument within the command the script does not work…
The following works…
grass.run_command(‘r.in.gdal’, input=‘/home/alassane/Data/SanbornCD/tile/newconstr_mask.tif’, output=‘construction’)
But not this…
command=“‘r.in.gdal’, input='”+sys.argv[5]+“', output=‘construction’”
print 'r.in.gdal command argument… = %s\n ’ % command
grass.run_command(command)
print ‘r.in.gdal command argument… = %s\n ’ % command
r.in.gdal command argument… = ‘r.in.gdal’, input=’/home/alassane/Data/SanbornCD/tile/newconstr_mask.tif’, output=‘construction’
The following also works…
command =“/home/alassane/Programs/gdal/demclass1”+" “+infile1+” “+infile2+” “+sys.argv[3]+” "+outfile
os.system(command)
Your help is appreciated.
Alassane
Hello,
You try to pass a string as an argument to run_command, which will not work.
If you want to change the input, change that string only:
for m in maps:
    grass.run_command('r.in.gdal', input=m, output=m)
or, as in your example:
grass.run_command('r.in.gdal', input=sys.argv[5], output='your_map')
For command line parsing, I recommend using GRASS parser or argparse.
For string formatting, use .format() instead of %, which is deprecated.
(https://docs.python.org/2/library/stdtypes.html#str.format)
Laurent
2016-08-11 15:04 GMT-05:00 alassane toure <atourej@gmail.com>:
Group,
within the command the script does not work....
The following works...
input='/home/alassane/Data/SanbornCD/tile/newconstr_mask.tif',
output='construction')
But not this...
command="'r.in.gdal', input='"+sys.argv[5]+"', output='construction'"
print 'r.in.gdal command argument... = %s\n ' % command
r.in.gdal command argument... = 'r.in.gdal',
The following also works...
command ="/home/alassane/Programs/gdal/demclass1"+" "+infile1+" "+infile2+"
"+sys.argv[3]+" "+outfile
os.system(command)
Alassane
grass-user mailing list
grass-user@lists.osgeo.org
