[GRASS-user] GRASS Script for importing data with different source_coordinates/projection
Greetings
This almost a follow-up from a previous message that I sent regarding Landsat-7 image importing.
I need to develop a script to import images from multi-SOURCE_COORDINATE_SYSTEM to defined target_COORDINATE_SYSTEM (WGS84). Since my input images come from different UTM zones it won’t be possible to import images using a pre-defined gdalwarp command to convert coordinate/projection systems, since source coordinates are more than one.
Firman made suggestion of using a GRASS Script to read header and get coordinate system.
Has anyone developed something similar to this?
Thyank you
Best regards,
Jenny
