After a few emails exchanged with Glynn I finally solved this:
*export GRASS_OVERWRITE=1
r.mapcalc "$GIS_OPT_CONTADOR= float(0)"
tmp=tmp.dwe.ndviserie.$$
IFS=,
for opt in $GIS_OPT_INPUT; do
r.mapcalc "$tmp = $opt + $GIS_OPT_CONTADOR"
g.rename rast=$tmp,$GIS_OPT_CONTADOR
done
r.info -r $GIS_OPT_CONTADOR*
To be noted:
- export is used in order to overwrite files
- I use a TMP that is defined by *tmp=tmp.dwe.ndviserie.$$
*- IFS is essential in order to define , as a separator symbol.
One question, Glynn: Where can I get more information about Bash script expression such as "export"?
Thanks
Antonio
António Rocha wrote:
Hey
I have tried Glynn's solution like this:
r.mapcalc "$GIS_OPT_COUNTER= float(0)"
tmp=tmp.myscript.$$
r.mapcalc "$tmp = $opt + $GIS_OPT_COUNTER"
g.rename rast=$tmp,$GIS_OPT_COUNTER
done
And I got
*/syntax error, unexpected ',', expecting $end
Parse error
raster <tmp.myscript.724> not found/*
I changed myscript to r.ndviserie/* */(myscript filename) and i got this:
/*syntax error, unexpected ',', expecting $end
Parse error
raster <tmp.dwe.ndviserie.3692> not found*/
It seems that he is not recognizing tmp as a file where to store an image.
yesterday I found a reference of initializing TMP files with a "r_fillnulls_". I try to find this function, or any reference to this, but nothing was found. What is this?
Thanks Glynn and everyone else
Antonio
Greetings Achim
You are absolutely right. I made a mistake copying the expression.
Here it goes:
#itinialization of counter1
r.mapcalc $GIS_OPT_COUNTER1= "float (0)"
The cycle:
IFS=,
r.mapcalc $GIS_OPT_COUNTER= "$opt+$GIS_OPT_COUNTER"
done
Don't use the same map as both input and output. Instead:
tmp=tmp.myscript.$$
g.rename --o rast=$tmp,$GIS_OPT_COUNTER
done
Although for this specific task (adding a list of maps), use
"r.series ... method=sum".
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4698 (20091218) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4743 (20100104) __________
http://www.eset.com
http://www.eset.com
