It would be very helpful to capture all GRASS commands and output in a
text file for each session. I believe this can be done by invoking grass
with the 'tee' command. Is there another, preferred way to do this?
Rich
Rich
Rich,
On Fri, Jun 8, 2012 at 6:33 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
with the ‘tee’ command. Is there another, preferred way to do this?
There is a .bash_history file stored in the PERMANENT mapset, it stores all the command logs you used in the sessions
ciao madi
Dr. Margherita Di Leo
madi,
There's also one in the project's mapset, but it has only the commands,
not the output of those commands sent to stdout. I'll see how successful
pipiging output through the tee command works for this.
Rich
Richard B. Shepard, Ph.D. | Integrity - Credibility - Innovation
Applied Ecosystem Services, Inc. | Helping Ensure Our Clients' Futures
<http://www.appl-ecosys.com> Voice: 503-667-4517 Fax: 503-667-8863
Use a terminal emulator with a "log to file" capabaility. Or use the
"script" command.
The main problem with "tee" is that it won't work with commands which
require a terminal.
"script" command.
Glynn,
OK. I'll see if urxvt supports logging.
Rich
2012/6/8 Rich Shepard <rshepard@appl-ecosys.com>:
slightly related --- GUI-oriented way how to create commands protocol
in wxGUI has been asked by Helena Mitasova during GRASS community
sprint in Prague [1], currently available for testing in G65 & G70.
See short video tutorial at [2].
Martin
[1] http://grass.osgeo.org/wiki/GRASS_Community_Sprint_Prague_2012
[2] http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Layer_Manager:_Commands_protocol
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
2012/6/8 Martin Landa <landa.martin@gmail.com>:
now (r52016) also in relbr64.
Martin
"script" command.
fyi, hints for using the `script` command can be found here:
http://www.debian.org/releases/stable/amd64/release-notes/ch-upgrading.en.html#record-session
Hamish
One wish: ignore the # character for comments, when copy-pasting
from enriched protocols:
# display elevation model:
[Errno 2] No such file or directory
d.rast elevation
thanks
