[GRASS-user] GRASS sites file
Luisa wrote:
What is a GRASS sites file? How can I obtain this?
a sites file is what vector points maps were called in earlier versions
of GRASS.
grass-addons/imagery/i.pr/TODO:
This module set was developed for GRASS 5.
TODO:
- change to ANSI prototypes
- follow SUBMITTING rules
- change sites to vector
There is a "cheap" coding option which supports the old sites API while
using new vector points maps. I don't know if these modules use that
or not. The real solution is to make them use the new vector API (not
so hard, documented into the wiki somewhere?).
Hamish
of GRASS.
TODO:
If i.pr compiles without warnings (regarding the sites API) it should
work in 6.x. Otherwise it's not much work to change it to use the new
vector API.
Markus M
The only warning that i get is:
warning: format not a string literal and no format arguments
Where is that “cheap trick”. Before I do any implementation i.ptr I have to understand that its classification works. So far, fraom all the messages that I have read, no one can use the classification…
Luisa
2010/5/19 Markus Metz <markus.metz.giswork@googlemail.com>
of GRASS.
TODO:
  • change to ANSI prototypes
  • follow SUBMITTING rules
  • change sites to vector
There is a “cheap” coding option which supports the old sites API while
using new vector points maps. I don’t know if these modules use that
work in 6.x. Otherwise it’s not much work to change it to use the new
vector API.
Markus M
Hi thereInstead of GRASS sites file I used a normal GRASS-vector and I got this error:
Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)
Since I’m only testing i.pr module I would like to know where can I get a conversion script/function between Vector->Site file?
If this runs ok I will implement this using GRASS vector.
Thanks
Luisa
2010/5/19 Luisa Peña <luisapena1979@gmail.com>
Luisa
of GRASS.
TODO:
vector API.
Markus M
Luisa Peña wrote:
Hi there
error:
This is not an error, it's simply a message meant for the developer
maintaining this module, not even a warning, you can safely proceed.
Since you used a normal GRASS vector, the module did not abort with an
error, right?
Since I'm only testing i.pr module I would like to know where can I get a
Thanks
Luisa
Where is that "cheap trick". Before I do any implementation i.ptr I have
that I have read, no one can use the classification...
Luisa
> of GRASS.
> TODO:
vector API.
Markus M
grass-user mailing list
grass-user@lists.osgeo.org
Yes you are absolutely right. It seems to work…
Where can I find this?
“here is a “cheap” coding option which supports the old sites API while
so hard, documented into the wiki somewhere?).”
Luisa
Luisa Peña wrote:
Hi there
error:
This is not an error, it’s simply a message meant for the developer
error, right?
Thanks
Luisa
Luisa
of GRASS.
TODO:
vector API.
Markus M
Luisa Peña wrote:
Yes you are absolutely right. It seems to work...
"here is a "cheap" coding option which supports the old sites API while
so hard, documented into the wiki somewhere?)."
The old sites API is deprecated. It does not allow modules to handle
old GRASS sites, instead a regular GRASS 6 vector with points is
required for the sites API in GRASS 6. Any module still using this old
sites API works just fine in GRASS 6 with a GRASS 6 vector. The i.pr
modules still use this API and should be updated, but that does not
mean that the i.pr modules need an old GRASS sites vector, instead
i.pr.training needs a regular GRASS 6 vector with points.
In short, as far as vector input for non-interactive i.pr.training is
concerned, the module should work just fine as is in GRASS 6.
Markus Metz:
Luisa Peña wrote:
> Hi there
> error:
> be
error, right?
> a
> Thanks
> Luisa
>> have
>> messages
>> Luisa
>>> > versions
>>> > of GRASS.
>>> > TODO:
>>> > while
>>> > (not
>>> vector API.
>>> Markus M
