[GRASS-user] GRASS, sqlite-driver an (german) umlaut - visible in GRASS, but not in sqlite!
Dear list,
I successfully imported a dbf-table into my grass-project. Attributes are stored in sqlite.
When I use the identify-tool of gis.m, german umlaut characters (üßöä)are displayed. However, using sqlite3-console or sqlitebrowser does not work. The same thing happens with QGIS (not displayed). Therefore, I cannot perform a query like "select * from layer where Ort like 'Münch%';" (only Mnchen available).
Is there a way to tell sqlite that I have this kind of characters?
I just tested v.out.ogr - fortunately, all ü,ö,ä,ß were visible in the attribute table of the exported (shape-)file.
Any ideas are appreciated!
With best regards,
Wolfgang
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Hello Wolfgang,
On Wed, 20 Sep 2006 10:27:40 +0200 "Wolfgang Qual"
<Wolfgang.Qual@gmx.net> wrote:
Dear list,
are stored in sqlite. When I use the identify-tool of gis.m, german
layer where Ort like 'Münch%';" (only Mnchen available). Is there a
way to tell sqlite that I have this kind of characters? I just tested
Did you check our locale-settings? Are they set correct for your
environment and for the sqlite-db as well?
Best regards
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
Hi Stephan,
I fear that I do not really understand, what you mean. Could you give me some additional info, where to look? printenv? When I type in "printenv" I get these information reg. language:
LANG=de_DE.UTF-8
LANGUAGE=\\\"de_DE:de:en_GB:en\\\"
As mentioned before, the umlaut(s) are displayed correctly in gis.m
Best regards,
Wolfgang
Best regards
  Stephan
grassuser mailing list
grassuser@grass.itc.it
Hello list, Stephan,
just a short remark to the above desribed problem.
When using xterm as the terminal programme, umlauts are correctly displayed in the command-line of sqlite (before, I used "konsole", a kde-application).
This gives me the possibility to perform sql-statements, which contain umlauts. However, this does not solve the sqlitebrowser-problem - could it be a qt3-issue? Anyway, I asked this question on the sqlite-user-list [1].
Best regards,
Wolfgang
[1] http://www.mail-archive.com/sqlite-users%40sqlite.org/msg18389.html
-------- Original-Nachricht --------
Datum: Wed, 20 Sep 2006 12:36:35 +0200
Von: "Wolfgang Qual" <Wolfgang.Qual@gmx.net>
An: Stephan Holl <holl@gdf-hannover.de>, grassuser@grass.itc.it
Betreff: Re: [GRASS-user] GRASS, sqlite-driver an (german) umlaut - visible in GRASS, but not in sqlite!
Hi Stephan,
LANG=de_DE.UTF-8
Best regards,
Wolfgang
> Best regards
> Stephan
NEU: GMX DSL Sofort-Start-Set - blitzschnell ins Internet!
Echte DSL-Flatrate ab 0,- Euro* http://www.gmx.net/de/go/dsl
Hello Wolfgang,
On Thu, 21 Sep 2006 10:25:34 +0200 "Wolfgang Qual"
kde-application).
Strange, I use the KDE- konsole and the umlauts are printed fine.
Perhaps an KDE-UTF8-issue?!
AFAIK sqlitebrowser should grab the locale-setting from KDE
environment, but I am not quite sure.
  Stephan
