I'm getting close to finishing up a generic code that sends any given
raster command to gridengine for parallel processing (I'll post it as
soon as its ready for testing), but I had a couple of quick question
on GRASS standards:
1) For a given mapset, is there a directory within it that is designed
for temporary, non-geospatial files (e.g. text parameter files)?
2) Is there an "official" way to remove a mapset from GRASS short of
rm -rf /pathto/mapset)?
Thanks! Would anyone be interested in testing out the code once its
done? If so, send me a message. You'll need to get gridengine
installed (or have access to a working gridengine server). I got it
installed in about 2 minutes on a debian system by just downloading
the binaries and running the install scripts that come with it (I had
NO luck getting the debian package via apt-get working, mind you).
any given raster command to gridengine for parallel processing
(I'll post it as soon as its ready for testing), but I had a
interesting..
couple of quick question on GRASS standards:
is designed for temporary, non-geospatial files (e.g. text
parameter files)?
see $MAPSET/.tmp/, G_tempfile(), and g.tempfile and perhaps a
python helper funtion too.
clean it up with $GISBASE/etc/clean_temp
short of rm -rf /pathto/mapset)?
No. (the startup gui has a button to do it, but I guess you
mean something scriptable)
code once its done? If so, send me a message. You'll need to
get gridengine installed (or have access to a working
gridengine server). I got it installed in about 2 minutes on
a debian system by just downloading the binaries and running
mind you).
On Tue, Mar 30, 2010 at 6:27 PM, Jonathan Greenberg
<greenberg@ucdavis.edu> wrote:
Folks:
