[GRASS-user] GRASS toolbar in QGIS
We are discussing possible UI cleanup related also to GRASS:
https://hub.qgis.org/issues/13537
Questions for plugin users:
- Can be open/new/close items removed from the toolbar? There is a
possibility to open mapset from browser and close it from tools dock
widget and there are menu items for all three actions.
- Should we keep Region action (region display on/off) in the toolbar,
it could be moved to the top of tools widget, beside Close mapset
button
- Is it "Open Tools" action in the toolbar useful? It is also in the
menu and tools may be opened like any other docked widget from
Settings > Panels
Radim
Hi Radim,
Personally, I do not rely on the buttons in the toolbar, so I have no objections to remove them from the toolbar.
Consistent UI (comparable to Processing) seems an appropriate priority...
Just some ideas for possible solutions:
"Show Region button" might go into the "Region tab" in the grass tools widget (instead of near close mapset)?
Close to the "Close mapset"-button in the tools widget, you might place the "Open mapset"-button from the toolbar?
In a GRASS entry in an "Analysis" Menu, you might place content from the context menu in the browser (GRASS tools settings and so on)?
Stefan
P.S.: I shall add that to the ticket...
-----Original Message-----
From: grass-user-bounces@lists.osgeo.org [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Radim Blazek
Sent: 7. oktober 2015 11:09
To: qgis-user List <qgis-user@lists.osgeo.org>; grass-user <grass-user@lists.osgeo.org>
Subject: [GRASS-user] GRASS toolbar in QGIS
- Can be open/new/close items removed from the toolbar? There is a possibility to open mapset from browser and close it from tools dock widget and there are menu items for all three actions.
- Should we keep Region action (region display on/off) in the toolbar, it could be moved to the top of tools widget, beside Close mapset button
- Is it "Open Tools" action in the toolbar useful? It is also in the menu and tools may be opened like any other docked widget from Settings > Panels
Radim
grass-user mailing list
Hi, testing the new GRASS plugin, i cannot find a way to
start a new project from scratch (option maybe removed while cleaning up
the toolbar);
what I mean: there is no more way to create a new GRASS LOCATION,
so that if there is not an already existing GRASS LOCATION I cannot use
the plugin
or maybe i can not find the way to do it?
Thanks, Roy.
Hi Roy,
the toolbar);
the plugin
Plugins → GRASS → New Mapset
Pedro
