[GRASS-user] GRASS unofficial addon installation
What is the best way to install an “unofficial” GRASS addon i.e. one not-hosted at the official SVN repository?
I just checked “g.extension -d” and AFAIK what you essentially need to do in order to install a “single” extension (i.e. not a toolbox) is to checkout the repository and issue make & make install with the correct arguments. I.e something like this:
make
MODULE_TOPDIR=/usr/lib/grass70
RUN_GISRC=/tmp/tmpXuk4Se
BIN=/checkout_dir/bin
HTMLDIR=/checkout_dir/docs/html
RESTDIR=/checkout_dir/docs/rest
MANBASEDIR=/checkout_dir/docs/man
SCRIPTDIR=/checkout_dir/script
STRINGDIR=/checkout_dir
ETC=/checkout_dir/etc
make
ARCH_DISTDIR=/checkout_dir
INST_DIR=/home/grassuser/.grass7/addons
install
Is this correct? Are there any caveats that I need to know about?
with kind regards,
Panos
PS, best wishes and a happy new year to everybody :slight_smile:
On Thu, Dec 31, 2015 at 5:59 PM, Panagiotis Mavrogiorgos
<pmav99@gmail.com> wrote:
What is the best way to install an "unofficial" GRASS addon i.e. one
You can specify non-standard repositories in
https://grass.osgeo.org/grass71/manuals/g.extension.html
(note that the version in G7.1 is quite advanced compared to that
included in G7.0.x)
I just checked "g.extension -d" and AFAIK what you essentially need to do in
order to install a "single" extension (i.e. not a toolbox) is to checkout
make \
    MODULE_TOPDIR=/usr/lib/grass70 \
    RUN_GISRC=/tmp/tmpXuk4Se \
    BIN=/checkout_dir/bin \
    HTMLDIR=/checkout_dir/docs/html \
    RESTDIR=/checkout_dir/docs/rest \
    MANBASEDIR=/checkout_dir/docs/man \
    SCRIPTDIR=/checkout_dir/script \
    STRINGDIR=/checkout_dir \
make \
    ARCH_DISTDIR=/checkout_dir \
    INST_DIR=/home/grassuser/.grass7/addons \
    install
Looks like overly complicated to me.
This job is essentially done by g.extension.
with kind regards,
Panos
Happy new Year!
included in G7.0.x)
Good to know :slight_smile: But I am afraid that at least for now I have to stick with
stable versions (i.e. G7.0.x)
do in
I agree that this is what g.extension does, but AFAIK g.extension does not
work with non-svn repositories. So my question is if is there anything else
that needs to be done in order to manually install a GRASS extension.
thanks,
Panos
included in G7.0.x)
Good to know :slight_smile: But I am afraid that at least for now I have to stick with stable versions (i.e. G7.0.x)
That’s fine of course and we’ll find a solution.
I agree that this is what g.extension does, but AFAIK g.extension does not work with non-svn repositories. So my question is if is there anything else that needs to be done in order to manually install a GRASS extension.
Does it need to stay in a remote directory? Or can you have the addon source code locally? The latter is easy to compile and install without any changes needed.
Not sure what your need is.
On Sun, Jan 3, 2016 at 4:56 PM, Panagiotis Mavrogiorgos <pmav99@gmail.com>
included in G7.0.x)
You can try to download g.extension source code and run it as a script.
It's not guaranteed that it will work but it is worth a try.
https://trac.osgeo.org/grass/browser/grass/trunk/scripts/g.extension
https://trac.osgeo.org/grass/export/67476/grass/trunk/scripts/g.extension/g.extension.py
needed.
If you have a local copy of the source code:
cd /path/to/source_of_addon/
make MODULE_TOPDIR=/path/to/compiled_code_of/grass70/
This will compile it.
