Thanks for the direction!
I have successfully worked through the examples on http://grass.osgeo.org/grass70/manuals/libpython/script_intro.html except for the last one about adding a module interface to a script. I copied the code into a python file named module_interface.py. After I File-> “Launch script” and select module_interface.py, the module GUI pops up and prompts for the raster inputs and output. But, after clicking on “Run”, the script reports the following message:
(Wed Mar 04 21:55:29 2015)
module_interface araster=el_D782_6m@PERMANENT braster=el_D783_6m@PERMANENT output=el_r_6m
‘module_interface’ is not recognized as an internal or
external command,
operable program or batch file.
(Wed Mar 04 21:55:29 2015) Command finished (0 sec)
Anyone seen this message?
Rob Parsons
Raleigh NC
On Sun, Mar 1, 2015 at 8:13 PM, <grass-user-request@lists.osgeo.org> wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
grass-user-request@lists.osgeo.orgYou can reach the person managing the list at
grass-user-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”Today’s Topics:
- GRASS 7.0 Running Scripts (.\GRASS GIS 7.0.0\scripts)
(Rob Parsons)- Re: GRASS 7.0 Running Scripts (.\GRASS GIS 7.0.0\scripts)
(Vaclav Petras)
Message: 1
Date: Sun, 1 Mar 2015 19:37:59 -0500
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] GRASS 7.0 Running Scripts (.\GRASS GIS
7.0.0\scripts)
Message-ID:
<CAFvPsPBH1xVpEgff15hxknY0qeeMUeehP9bucV4FB9ZgQ_2+cg@mail.gmail.com>
Content-Type: text/plain; charset=“utf-8”Hello,
How do I run scripts located in C:\Program Files (x86)\GRASS GIS
7.0.0\scripts?I am learning GRASS 7.0.0 on Windows 7 by converting some GRASS 6.4 shell
scripts to GRASS 7 Python scripts (import grass.script as grass) and GRASS
7 PyGRASS scripts (from grass.pygrass.modules import Module).My installation is working fine. I can manually run the commands (from a
shell script) in the “Command console” window of the “Layer Manager”. For
example, I can enter “g.region swwake_30m -p” in the “Command prompt” area
and get the following results:Sun Mar 01 12:32:30
2015)
g.region swwake_30m
-p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 30
ewres: 30
rows: 450
cols: 500
cells: 225000
(Sun Mar 01 12:32:31 2015) Command finished (0
sec)I am using the “Pythonwin” IDE to develop the scripts (C:\Program Files
(x86)\GRASS GIS 7.0.0\Python27\lib\site-packages\pythonwin\Pythonwin.exe).
In the “GRASS GIS 7.0.0 GUI” Command Prompt window I type “pythonwin” and
the IDE starts up.I have spent several days trying to understand how to create GRASS Python
scripts and GRASS PyGRASS scripts from the online documentation(
http://grasswiki.osgeo.org/wiki/GRASS_and_Python) and by studying the
script samples (C:\Program Files (x86)\GRASS GIS 7.0.0\scripts). I have not
been successful in getting example code to run but I am still working
through the documentation.But, I should be able to run scripts located in C:\Program Files
(x86)\GRASS GIS 7.0.0\scripts.Correct?
- If I open .\scripts[d.what.rast.py](http://d.what.rast.py) in the Pythonwin IDE and try to run
it, I get this output:OSError error(9): The handle is invalid
File “C:\Program Files (x86)\GRASS GIS
7.0.0\Python27\lib\site-packages\pythonwin\pywin\framework\scriptutils.py”,
line 325, in RunScript
exec codeObject in main.dict
File
“C:\Users\Rob\Documents\grassscripts\pygrass\make_raster_using_mapcalc.py”,
line 8, in
g.message(“Filter elevation map by a threshold…”)
7.0.0\etc\python\grass\pygrass\modules\shortcuts.py”, line 46, in
getattr
return self.cls(‘%s.%s’ % (self.prefix, name.replace(‘_’, ‘.’)))
7.0.0\etc\python\grass\pygrass\modules\interface\module.py”, line 498, in
init
raise GrassError(str_err % self.name)
GrassError: Error running:g.message --interface-description
File “C:\Program Files (x86)\GRASS GIS 7.0.0\scripts[d.what.rast.py](http://d.what.rast.py)”,
line 45, in
main()
line 30, in main
options, flags = gcore.parser()
7.0.0\etc\python\grass\script\core.py”, line 680, in parser
p = subprocess.Popen([prog, ‘-n’] + argv, stdout=subprocess.PIPE)
File “C:\Program Files (x86)\GRASS GIS 7.0.0\Python27\lib\subprocess.py”,
line 703, in init
errread, errwrite) = self._get_handles(stdin, stdout, stderr)
line 839, in _get_handles
p2cread = self._make_inheritable(p2cread)
line 878, in _make_inheritable
_subprocess.DUPLICATE_SAME_ACCESS)
WindowsError: [Error 6] The handle is invalid
line 45, in
main()
line 30, in main
line 703, in init
- If I go to the “Python shell” tab on the “Layer Manager” and do File →
Launch Script and browse to .\scripts[d.what.rast.py](http://d.what.rast.py), I get this output:(Sun Mar 01 12:32:31 2015) Command finished (0
sec)
Launching script ‘C:\Program Files (x86)\GRASS GIS 7.0.0\scripts
d.what.rast.py’…
7.0.0\gui\wxpython\gui_core\forms.py”, line 718, in OnRungcmd.Command(cmd)
7.0.0\gui\wxpython\core\gcmd.py”, line 397, in init_("Error: ") + self.__GetError()))
core.gcmd
GException
Execution failed: ‘d.what.rast map=elevation’
Details:
Error:Any ideas on what might be going on here?
Rob Parsons
Raleigh NC
An HTML attachment was scrubbed…
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150301/b41b2959/attachment-0001.html>
Message: 2
Date: Sun, 1 Mar 2015 20:12:57 -0500
To: Rob Parsons <jrobparsons@gmail.com>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] GRASS 7.0 Running Scripts (.\GRASS GIS
7.0.0\scripts)
Message-ID:
<CABo5uVt7hq0QnHYqzV5O949h3URGxFOAjHNLxiMx=V5rSK_wRw@mail.gmail.com>
Content-Type: text/plain; charset=“utf-8”On Sun, Mar 1, 2015 at 7:37 PM, Rob Parsons <jrobparsons@gmail.com> wrote:
Hello,
2015)
g.region swwake_30m
-p
zone: 0
datum: nad83
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 30
ewres: 30
rows: 450
cols: 500
cells: 225000
through the documentation.Please try the example from:
I linked this page from documentation as well as the other Python wiki page
from the GRASS and Python page:http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
Note that GRASS scripts by default cannot run from outside GRASS GIS
session (environment). This is probably not emphasized enough in the
Correct?
Correct but can you please try some other module than a d.* module, e.g.
r.out.xyz? d.* commands are somehow special (although in this case it
probably doesn’t matter).
File
line 8, in
getattr
init
line 45, in
main()
line 30, in main
7.0.0\Python27\lib\subprocess.py”, line 703, in init
7.0.0\Python27\lib\subprocess.py”, line 839, in _get_handles
7.0.0\Python27\lib\subprocess.py”, line 878, in _make_inheritable
line 45, in
main()
line 30, in main
WindowsError: [Error 6] The handle is invalidThis might be somehow related to bug in Python itself:
http://bugs.python.org/issue3905
However, please focus on running the scripts for GRASS GIS from GRASS
session. The easiest way how to do that on MS Windows is to write the
script and then to start it from GUI (File > Run script) or from Python
shell tab in the GUI.It is possible to run scripts which are using GRASS modules from outside of
GRASS session but it requires you to set up the GRASS environment yourself.
This is possible but it has some challenges. On the other hand, if you
write your script in the way that it runs (only) in a GRASS session you can
use GRASS features for automatic building of interface and thus create a
true GRASS module.
sec)
d.what.rast.py’…
core.gcmd
GException
Details:
Error:The error message seems to be incomplete but in any case, please try with
r.out.xyz script and the example script from:http://grass.osgeo.org/grass70/manuals/libpython/script_intro.html
Vaclav
Rob Parsons
Raleigh NC
http://lists.osgeo.org/mailman/listinfo/grass-user-------------- next part --------------
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150301/6ff05a0b/attachment.html>
http://lists.osgeo.org/mailman/listinfo/grass-userEnd of grass-user Digest, Vol 107, Issue 2
