[GRASS-user] grass-user Digest, Vol 180, Issue 4
Problem with wxpython guy in Manjaro with grass 7.8.5
Dear colleagues,
Following a period of low use due to health issues I am once again trying to use GRASS to visualise and analyse archaeological data.
I am running Manjaro and the latest download of GRASS from AUR.
It starts fine and shows both display windows for the GUI and then the windows crash. It is repeatable.
I have tried removing GRASS and reinstalling but that has not fixed the issue. As well I have tried changing the flags on the GUI. None make any difference, as soon as the mouse is apparently moved the windows crash.
Is this a known problem and is there a work around?
Thanks
Tim Southern
Dr Timothy Glyn Southern
0155 941 8432
0791 076 6814
On 4 Apr 2021, at 20:00, grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”
Today’s Topics:
  1. Re: r.watershed identify inland watershed (ming han)
Message: 1
Date: Sat, 3 Apr 2021 16:23:26 -0400
To: Micha Silver tsvibar@gmail.com
Cc: GRASS user list grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] r.watershed identify inland watershed
Message-ID:
CAD+uAWjx1XBcc6jk+hau8MnDa7CEAJfWeeEyEWq379efWrpMkw@mail.gmail.com
Content-Type: text/plain; charset=“utf-8”
Hi Micha
I understand what you mean. But it requires another step to
manually identify depressions from these pre-conditioned DEM.
Ming
Micha Silver tsvibar@gmail.com ?2021?4?3??? ??12:43???
On 4/2/21 5:37 PM, ming han wrote:
Maybe I am the only one who has this demand. Following is just a
recommendation to GRASS r.watershed function.
Maybe it is worth having an option to avoid r.watershed overcome
depressions.
The reasons are 1) there are many hydrologically pre condition DEM
data available globally, such as:HydroSHEDS, MERIT
2) the depression in these DEM are real
depressions, overcome these depressions will make the entire drainage
system
Regarding Hydrosheds, the documentation[1] in section 3.4 explains how
they overcame the problem of sinks. They performed a regular “fill
sinks” operation on areas that were SRTM artifacts. True natural
depressions were identified manually, then another manual procedure of
carving rivers was done to force flow thru these depressions and produce
hydrologically correct streams and basins. So pre-conditioning to
overcome depressions is not a magic bullet…
In my opinion, the best results are obtained when true depressions
(pits, salt playas or karst regions) are identified, and set to NULL in
the elevation raster. That will allow r.watershed to stop routing at
those locations, and produce correct stream and basin layers.
[1]https://hydrosheds.org/images/inpages/HydroSHEDS_TechDoc_v1_2.pdf
incorrectly.
I understand GRASS has other functions to solve this problem, but just
a user recommendation. I use GRASS a lot.
Thanks
Ming
ming han <dustming@gmail.com mailto:dustming@gmail.com>
?2021?3?30??? ??8:06???
Got it, thanks everyone~
Ming
Micha Silver <tsvibar@gmail.com mailto:tsvibar@gmail.com>
?2021?3?29??? ??2:40???
Hello:
You might try r.param.scale, or even better r.geomorphons
modules to
identify geomorphology features, then filter out all pixels
identified
as pits.
r.watershed is purposely designed to overcome depressions, and
find flow
routing thru these spots. So I don’t think you can use that
module to
identify depressions.
On 3/27/21 8:49 PM, ming han wrote:
Hi Everyone
When I do watershed delineation using r.watershed for
great salt
lake watershed. I found r.watershed always tried to assign
an outlet
for a great salt lake, which does actually not exist because
it is an
inland lake and the great salt lake has no watershed outlet
at all.
I noticed that there is a depression option. But is
there any
way that r.watershed can automatically identify depressions
while
defining flow accumulation and stream network?
Thanks
Ming
grass-user@lists.osgeo.org mailto:grass-user@lists.osgeo.org
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Micha Silver
Ben Gurion Univ.
An HTML attachment was scrubbed…
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20210403/6b22a457/attachment-0001.html
Subject: Digest Footer
End of grass-user Digest, Vol 180, Issue 4
The problem I have just posted appears to be the same as ticket 1123 and 1261 yet they were supposedly resolved in January. The issue appears to be that the promised wxPython 4.0.8 is still not used in the build but the problematic 4.0.7.
Is there any news on when either wxPython 4.0.8 will be available?
Thanks
Tim Southern
0155 941 8432
0791 076 6814
On 10 Apr 2021, at 17:43, Timothy Glyn Southern <tim.southern@talktalk.net> wrote:
Dear colleagues,
Thanks
Tim Southern
0155 941 8432
0791 076 6814
Today’s Topics:
Message: 1
Message-ID:
Hi Micha
Ming
depressions.
system
incorrectly.
Thanks
Ming
Ming
Hello:
modules to
identified
as pits.
find flow
module to
Hi Everyone
great salt
an outlet
it is an
at all.
there any
while
Thanks
Ming
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Hello,
On Sat, Apr 10, 2021 at 12:51 PM Timothy Glyn Southern via grass-user <grass-user@lists.osgeo.org> wrote:
Dear colleagues,
based on your description it sounds like a bug in wxPython with Python 3.9:
https://github.com/OSGeo/grass/issues/1123
Hope that helps,
Anna
Thanks
Tim Southern
0155 941 8432
0791 076 6814
Today’s Topics:
Message: 1
To: Micha Silver <tsvibar@gmail.com>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Message-ID:
<CAD+uAWjx1XBcc6jk+hau8MnDa7CEAJfWeeEyEWq379efWrpMkw@mail.gmail.com>
Hi Micha
Ming
Micha Silver <tsvibar@gmail.com> ?2021?4?3??? ??12:43???
depressions.
system
incorrectly.
Thanks
Ming
ming han <dustming@gmail.com mailto:[dustming@gmail.com](mailto:dustming@gmail.com)>
Ming
Micha Silver <tsvibar@gmail.com mailto:[tsvibar@gmail.com](mailto:tsvibar@gmail.com)>
Hello:
modules to
identified
as pits.
find flow
module to
Hi Everyone
great salt
an outlet
it is an
at all.
there any
while
Thanks
Ming
grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
<https://lists.osgeo.org/mailman/listinfo/grass-user>
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210403/6b22a457/attachment-0001.html>
Thanks Anna, I believe you are correct with your ideas, unfortunately the only fix given is way beyond my level of understanding and coding and from what I gather uses a non svn version python 4.1. There was a mention in that link to a newer version of python 4.0.8 but it seems it has not either been implemented or if it has uploaded to the repository.
Evidently the bug is in both python 3.9 and the 4.0 version currently used in the repository.
Is there likely to be an updated version loaded to repository before too long that corrects the problem?
Kind regards
Tim
On 11 Apr 2021, at 04:55, Anna Petrášová <kratochanna@gmail.com> wrote:
Hello,
Dear colleagues,
Hope that helps,
Anna
Thanks
Tim Southern
0155 941 8432
0791 076 6814
Today’s Topics:
Message: 1
Message-ID:
Hi Micha
Ming
depressions.
system
incorrectly.
Thanks
Ming
Ming
Hello:
modules to
identified
as pits.
find flow
module to
Hi Everyone
great salt
an outlet
it is an
at all.
there any
while
Thanks
Ming
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Hi Tim,
On Sun, Apr 11, 2021 at 10:42 AM Timothy Glyn Southern via grass-user
AFAIK the needed upstream fix on wyPython was this:
https://github.com/wxWidgets/Phoenix/pull/1849/files
merged into their master on Nov 18, 2020. I have no idea in which
wxPython release this will be/has been included.
https://archlinux.org/packages/community/x86_64/python-wxpython/
--> python-wxpython 4.0.7.2-5, Build Date: 2020-11-12
      ==> too old.
https://github.com/wxWidgets/Phoenix/releases
on Nov 25, 2020: wxPython-4.1.1
      ==> not yet packaged.
(Note that I am only guessing around here.)
Since I use Fedora (33) and didn't want to wait I contacted the
maintainer in Nov 2020.
They patched the package accordingly, added the aforementioned fix:
https://src.fedoraproject.org/rpms/python-wxpython4/c/f5471fb86aaae46a686b85c654fcbb98516355e6?branch=rawhide
and shipped the updated 4.0.7-13 RPM package right away, end of Nov 2020.
Maybe you could request to apply the fix also in the Manjaro package?
The packagers need to be aware of it...
Best,
