[GRASS-user] grass-user Digest, Vol 85, Issue 11
Made a little shell-script solving this earlier question of mine. Maybe someone else will need this as well....
patrick
###INIT:make copy of file (name "short" is used as indicator)
g.copy vect=myfile,myfile_short --o
###iterate through all columns, all files and check double column-name
###for all files of name *_short
for z in $(g.mlist type=vect pattern='*_short')
do
     for i in $(db.columns table=${z})
     do
         col=$(echo ${i} |cut -b 1-10)
         ###rename if longer then 10char
         if [ "$i" != "$col" ]
             then
                 ###check if new columnname already exists, e.g. name=>nam1
                 list=$(db.columns table=${z})
                 if [[ "$list" == *" $col "* ]]
                     then
                     x= #no value for first iteration
                     while [[ "$list" == *" $col "* ]]
                     do
                         echo "WARNING: columns is already existing => renaming"
                         col=$(echo ${col} |cut -b 1-9)
                         col=$(echo ${col}${x})
                         echo "new name $col"
                         x=$(( $x + 1 ))
                     done
                 fi
                 v.db.renamecol map=${z} col="${i},${col}"
                 echo "WARNING: file ${z} => Column ${i} is renamed to ${col}"
         fi
     done
done
On 05/08/2013 10:33 AM, grass-user-request@lists.osgeo.org wrote:
Message: 5
Date: Wed, 08 May 2013 09:28:06 +0200
To: grass mailing list<grass-user@lists.osgeo.org>
Subject: [GRASS-user] truncate column names for export?
Message-ID:<5189FE86.2060508@gmx.ch>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Dear all,
Is there an option to automatically truncate column-names (sqlite) to
fit for export format in v.in.ogr?
Export to shapefile, creates errors as soon as the column-names are
longer then the dbf-format can handle. It would be great to have an
option to automatically truncate and give out a warning instead of an
error. In case of same column-names (after truncating), last letter
could be replaced by a number.
However I don't see that this is implemented yet - or did I miss something?
