[GRASS-user] grass-user Digest, Vol 90, Issue 35
Hello, did you try to transform your line vector into a polygon vector and use after a v.clean command with tool=rmarea ? So only the small area will be removed and after you can again transform your polygon vector into a lin vector Mick
(attachments)
Le 21/10/2013 16:48, grass-user-request@lists.osgeo.org a écrit :
Send grass-user mailing list submissions to
	[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
To subscribe or unsubscribe via the World Wide Web, visit
	[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
or, via email, send a message with subject or body 'help' to
	[grass-user-request@lists.osgeo.org](mailto:grass-user-request@lists.osgeo.org)
You can reach the person managing the list at
	[grass-user-owner@lists.osgeo.org](mailto:grass-user-owner@lists.osgeo.org)
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
   1. How to delete small closed lines, problems with v.edit and
      v.generalize (BLANDENIER Lucien)
Message: 1
Date: Mon, 21 Oct 2013 14:48:21 +0000
From: BLANDENIER Lucien [<lucien.blandenier@unine.ch>](mailto:lucien.blandenier@unine.ch)
To: ["grass-user@lists.osgeo.org"](mailto:grass-user@lists.osgeo.org) [<grass-user@lists.osgeo.org>](mailto:grass-user@lists.osgeo.org)
Subject: [GRASS-user] How to delete small closed lines, problems with
	v.edit and v.generalize
Message-ID:
	[<84F1DDBD03D55944AA4E63A2FE5EADE5530A7CFE@MAIL-MBX-05.UNINE.CH>](mailto:84F1DDBD03D55944AA4E63A2FE5EADE5530A7CFE@MAIL-MBX-05.UNINE.CH)
Content-Type: text/plain; charset="iso-8859-1"
Hello,
I'm trying to simplify a contour map I've done with r.contour. I want to remove small area but when I use the command v.edit map=<map> tool=delete thresh=1000 query=length, only "non-closed map" are considered and the "closed line" (there are really lines, not polygons) remain.
I've the same problem with the command v.generalize.
Does someone knows how to consider all the lines ?
Attached is my shp.
Regards
Lucien
Type: application/octet-stream
Desc: Head_Interp_Rast_contour.dbf
URL: [<http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.obj>](http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.obj)
Desc: Head_Interp_Rast_contour.prj
URL: [<http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment-0001.obj>](http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment-0001.obj)
Type: application/x-qgis
Desc: Head_Interp_Rast_contour.shp
URL: [<http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.shp>](http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.shp)
Desc: Head_Interp_Rast_contour.shx
URL: [<http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.shx>](http://lists.osgeo.org/pipermail/grass-user/attachments/20131021/1427281b/attachment.shx)
End of grass-user Digest, Vol 90, Issue 35
INRA
Michael Rabotin
Ingénieur d’Etude SIG / GIS Engineer
michael.rabotin@supagro.inra.fr
UMR LISAH - Centre de Montpellier
Tèl. : +33 (0)4 99 61 23 85
Mobile : +33 (0)6 76 45 46 83
Fax : +33 (0)4 67 63 26 14
Bat 24 - 2 place Pierre Viala
34060 Montpellier cedex 2
France
www.inra.fr
www.openfluid-project.org
