Hello list,
I imported a large polygon shapefile using v.in.ogr. First, no topology was
available, so I ran v.build. However, when I try to display it with d.vect, I
get this error message. Does anybody know, what could be the reason for this?
The error message / warning:
GRASS 6.1.cvs (muenchen):~ > d.vect sgk_geb
WARNING: coor files of vector 'sgk_geb@sqlite_test' is larger than it
should be (55856074 bytes excess).
wqual napisa?(a):
Hello list,
I *guess* that your vector was not completely imported, as v.in.ogr
might fail on big datasets deue to limitations of current vector engine
(didn't you miss an error message from v.in.ogr?; in TCL/TK GUI some low
level errors are filtered out
http://intevation.de/rt/webrt?serial_num=3010, so try from CLI and see
what it says then).
Assuming my assumption is OK
you had to run v.build to build the
topology of your partially imported, corrupted vector. But still some
corrupted leftovers remain. Then try opening the vector in v.digit and
quit - this will extract what is recoverable from the file and write it
back.
Maciek
