hi,
while doing shortest path in grass i get the below error:
echo "1 1 2" | v.net.path mydgn_net afcol=forward abcol=backward out=myp
Building graph:
Registering arcs ... 100%
Flattening the graph ... done.
Graph was built.
WARNING: 8032 points without category (nfield: 2).
WARNING: No point with category 1
WARNING: No point with category 2
Attributes:
cat - path unique category assigned by module
id - path id (read from input)
fcat - from point category
tcat - to point category
sp - result status:
0 - OK, path found
1 - node is not reachable
2 - point of given category does not exist
cost - travelling costs (on the network, not to/from network)
fdist - the distance from first point to the network
tdist - the distance from the network to second point
WARNING: 2 points of given category missing
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Kindly, assisty me with this
that is not an error - you just did not calculate anything, because of
"WARNING: 2 points of given category missing"
are you sure, there are points with categories 1 and 2 in your input
file?
j
ec.jkd@tpcsed.com píše v Po 10. 12. 2007 v 15:15 +0530:
hi,
Building graph:
Graph was built.
Attributes:
sp - result status:
0 - OK, path found
0 areas built
0 isles built
Attaching islands:
Number of nodes : 0
Number of lines : 0
Number of areas : 0
Number of isles : 0
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky@gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
