Noway.
Even switching to develbrunch I receive the same error:
usr/local/lib/libgdal.so: undefined reference to `G_no_gisinit'
It appears for many binaries (various vector, raster and others commands).
I also receive tens of warnings, but it's secondary...
2008/8/12 Michael Barton <michael.barton@asu.edu>:
Let me know if this solves the issue.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State UniversityPhone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>On Aug 12, 2008, at 9:14 AM, G. Allegri wrote:
Anyway, as Michel has noted from my #254 ticket, I hadn't switch to
develbranch_6 yet, so I was trying to compile grass 7 (in trunk). In
fact I was receiving tons of errors...
I'm doing a brand new checkout from develbranch_6 right now.2008/8/12 Michael Barton <michael.barton@asu.edu>:
My understanding is that if you do a make distclean, you do not need to
do a
make clean too.Michael
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>On Aug 12, 2008, at 9:02 AM, Nikos Alexandris wrote:
On Tue, 2008-08-12 at 08:45 -0700, Michael Barton wrote:
On Aug 12, 2008, at 2:23 AM, <grass-user-request@lists.osgeo.org>
wrote:Date: Tue, 12 Aug 2008 11:21:19 +0200
Subject: Re: [GRASS-user] grass6.4.svn revision32686: failed to
compile r.terraflow and nviz2
To: "G. Allegri" <giohappy@gmail.com>
Cc: grassuser <grass-user@lists.osgeo.org>
Message-ID:
<f8fe65c40808120221o21b8ce0ax5d816981a5a358c3@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1Hi,
2008/8/12 G. Allegri <giohappy@gmail.com>:
neither r.terraflow nor nviz2.
From the error log, it seems to me that nviz library name is missing,
re-run configure script to fix it.
Martin
Maybe do a make clean or make distclean before compiling.
I always thought both are necessary (?) after a configuration and a
"make".make clean --> cleans "make"d files
make distclean --> cleans configuration filesIs that correct?
Nikos
grass-user mailing list
