[GRASS-user] grass6.4.svn revision32686: failed to compile r.terraflow and nviz2
On Aug 12, 2008, at 2:23 AM, <grass-user-request@lists.osgeo.org> wrote:
Date: Tue, 12 Aug 2008 11:21:19 +0200
Subject: Re: [GRASS-user] grass6.4.svn revision32686: failed to
To: "G. Allegri" <giohappy@gmail.com>
Cc: grassuser <grass-user@lists.osgeo.org>
Message-ID:
  <f8fe65c40808120221o21b8ce0ax5d816981a5a358c3@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
2008/8/12 G. Allegri <giohappy@gmail.com>:
neither r.terraflow nor nviz2.
From the error log, it seems to me that nviz library name is missing,
re-run configure script to fix it.
Martin
Maybe do a make clean or make distclean before compiling.
I just did an update (r32709) and compile for svn develbranch_6 (GRASS 6.4) with no problems for r.terraflow. I'm on a Mac with OS X 10.5.4
The new nviz (nviz2) has never compiled on Mac. Martin is working out the basic functionality of this brand new wxPython replacement for NVIZ. It compiles on at least some Linux systems, but may not compile on all. I've not heard reports from anyone trying to compile this under Windows yet.
Michael
> From: "Martin Landa" <landa.martin@gmail.com>
> Message-ID:
> Hi,
> Martin
I always thought both are necessary (?) after a configuration and a
"make".
make clean --> cleans "make"d files
make distclean --> cleans configuration files
Is that correct?
Nikos
My understanding is that if you do a make distclean, you do not need to do a make clean too.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
Message-ID:
Martin
"make".
Is that correct?
Nikos
Anyway, as Michel has noted from my #254 ticket, I hadn't switch to
develbranch_6 yet, so I was trying to compile grass 7 (in trunk). In
fact I was receiving tons of errors... :slight_smile:
I'm doing a brand new checkout from develbranch_6 right now.
2008/8/12 Michael Barton <michael.barton@asu.edu>:
make clean too.
Michael
Phone: 480-965-6262
Fax: 480-965-7671
Message-ID:
Martin
"make".
Is that correct?
Nikos
grass-user mailing list
Let me know if this solves the issue.
Michael
Phone: 480-965-6262
Fax: 480-965-7671
make clean too.
Michael
Phone: 480-965-6262
Fax: 480-965-7671
Message-ID:
Martin
"make".
Is that correct?
Nikos
Michael
> "make".
> Is that correct?
> Nikos
Michael,
you are right. It might be funny but I got used to do first "sudo make
clean" and then "sudo make distclean" and, important, I never found a
crystal-clear explanation about "cleaning". Maybe I did not search
enough the web.
Kind regards, Nikos
> > "make".
> > Is that correct?
> > Nikos
Michael,
enough the web.
"make clean" removes all of the files which are generated by the
"make" step. "make distclean" first performs "make clean" then also
removes any files which are generated by the "configure step".
If configure or any of the *.in files have changed, it is necessary to
run "make distclean" before compiling. Otherwise, "make clean" is
sufficient. It's safest to just use "make distclean" whenever the code
is updated.
