Hello Im a new user of GRASS. Im experiencing the following issue, while trying to run Grass on OSX,
apparently NumPy is not installed, but I have built it and installed successfully.
Any help will be welcome!
Fran
GRASS 6.4.3 (nc_basic_spm_grass7):~ > wxnviz.py: This module requires the NumPy module, which could not be imported. It probably is not installed (it’s not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries.
File “/opt/local/share/grass-6.4.3/etc/wxpython/wxgui.py”, line 34, in
from lmgr.frame import GMFrame
File “/opt/local/share/grass-6.4.3/etc/wxpython/lmgr/frame.py”, line 46, in
from lmgr.layertree import LayerTree, LMIcons
File “/opt/local/share/grass-6.4.3/etc/wxpython/lmgr/layertree.py”, line 37, in
from mapdisp.frame import MapFrame
File “/opt/local/share/grass-6.4.3/etc/wxpython/mapdisp/frame.py”, line 52, in
from wxplot.profile import ProfileFrame
File “/opt/local/share/grass-6.4.3/etc/wxpython/wxplot/profile.py”, line 23, in
import wx.lib.plot as plot
File “/opt/local/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/wx-2.8-gtk2-unicode/wx/lib/plot.py”, line 132, in
raise ImportError, “Numeric,numarray or NumPy not found. \n” + msg
ImportError: Numeric,numarray or NumPy not found.
This module requires the Numeric/numarray or NumPy module,
