I installed GRASS 7 and QGis from the https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable (Trusty 14.04) in Linux Mint 17.1 two weeks ago (sudo apt-get install postgis libgdal1h grass-dev grass-gui monteverdi2) and GRASS7 worked well for a week and now I have the following Error when I start the GRASS terminal:
Starting GRASS GIS…
(python:14221): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion ‘GTK_IS_WIDGET (widget)’ failed
I have uninstalled GRASS and installed again but I sill get the same error. How can I fix this error?
Further, QGIS doesn’t recognize GRASS7. Actually, I can see GRASS 7 on the QGis toolbox but it doesn’t work.
Is QGis prepared to support GRASS 7 through the QGIS/GRASS plugin? When I run the GRASS 7 from QGis toolbox I have the following Error:
GRASS_INFO_MESSAGE(14387,3): r.composite complete. Raster map created.
GRASS_INFO_END(14387,3)
GRASS_INFO_ERROR(14389,1): Raster map or group not found
GRASS_INFO_END(14389,1)
Execution of ‘/home/thayse/.qgis2//processing/grass7_batch_job.sh’ finished.
Cleaning up temporary files…
Starting GRASS GIS…
Executing ‘/home/thayse/.qgis2//processing/grass7_batch_job.sh’ …
GRASS_INFO_ERROR(14401,1): Raster map or group not found
GRASS_INFO_END(14401,1)
Converting outputs
Loading resulting layers
Is possible to have GRASS 6.4 installed in parallel to GRASS 7? What would be the best way to have both GRASS 6.4 and GRASS 7.0 installed on Linux Mint 17.1 from repositories?
Many thanks for your help.
Regards
Thayse Nery
PhD. Student
School of Agricultural and Resource Economics (M089)
The University of Western Australia
35 Stirling Highway, Crawley WA 6009, Australia
