GeoBSD
December 4, 2012, 4:59pm
1
Despite of the update of : "config.guess" and "confi.sub" (found here : http://git.savannah.gnu.org/cgit/config.git/tree ),
The outcome of "./configure" is still the same :
" configure: error: ***Unknown platform: i386-unknown-freebsd9.0*** "
Anyone an idea ?
It is now also in GRASS 7.svn.
Anyone an idea ?
Supported is this in config.guess:
*:FreeBSD:*:*)
UNAME_PROCESSOR=`/usr/bin/uname -p`
case ${UNAME_PROCESSOR} in
amd64)
echo x86_64-unknown-freebsd`echo ${UNAME_RELEASE}|sed
-e 's/[-(].*//'` ;;
echo ${UNAME_PROCESSOR}-unknown-freebsd`echo
${UNAME_RELEASE}|sed -e 's/[-(].*//'` ;;
esac
exit ;;
Can you please post the result of
uname -a
Pierre,
Anyone an idea ?
Please try again with the current GRASS 7 version from SVN.
Relevant pieces have been updated.
Please let us know if it compiles now.
GeoBSD
March 25, 2013, 10:31pm
4
There are some specific aspects on compiling Grass7 on FreeBSD 9.1.
1. Must use "gmake" instead of "make". 'Make' is different under BSD
Environnement.
2. The 'gis.h' header try to include the 'alloca.h' header. On FreeBSD,
alloca() is declared in 'stdlib.h'
(http://forums.freebsd.org/showthread.php?t=30354 ).
This issue was temporarily fixed with : ' #touch
/usr/local/include/alloca.h '
3. Current error appears in ' grass7/dist.i386-freebsd/lib/manage ' :
ld: unrecognized option '-Wl, -rpath, /grass7/dist.i386-freebsd/lib
Possible solution could be found in LD_SEARCH_FLAGS like in this post (https://trac.osgeo.org/grass/ticket/1757#comment:4 ).
I try to modify line 562 in ' aclocal.m4 ' and replace
SHLIB_LD="ld -Bshareable -x"
by SHLIB_LD="${CC} -shared"
But it didn't work.
Maybe one of us have already a solution ?
Environnement.
This seems to be true for most BSD and UNIX systems.
gis.h is fixed in r55519.
But it didn't work.
If you use
you must also use
LD_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
You would also need to patch configure or run autoconf (version 2.13).
HTH,
Markus M
PS: grass 7 compiles for me on FreeBSD 9.0 with SHLIB_LD="ld
-Bshareable -x", even though it should actually fail.
On Tue, Mar 26, 2013 at 10:10 AM, Markus Metz
Environnement.
But it didn't work.
If you use
you must also use
HTH,
Markus M
G7 compiles and runs for me on FreeBSD 9.0 with either
or
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
The former is now the default in r55521.
Markus M
