[GRASS-user] Grass7 r.in.lidar compile error
I just checked out the latest grass 7 from svn (r 46749) and tried to
compile with the liblas option but I'm seeing the following error in
r.in.lidar. It says I'm missing ogr_srs_api.h.
I'm running Ubuntu 9.10 (I know, very old distro)
Thanks
Daniel
daniel@xadrez:~/grass/grass_trunk/raster/r.in.lidar$ make
gcc -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.c
In file included from main.c:26:
/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29:
error: ogr_srs_api.h: No such file or directory
/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:84:
error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
‘GPJ_grass_to_osr’
/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:88:
error: expected declaration specifiers or ‘...’ before
‘OGRSpatialReferenceH’
main.c: In function ‘main’:
main.c:281: warning: format not a string literal and no format arguments
main.c:296: warning: format not a string literal and no format arguments
main.c:376: warning: format not a string literal and no format arguments
main.c:379: warning: format not a string literal and no format arguments
main.c:391: warning: format not a string literal and no format arguments
main.c:485: warning: format not a string literal and no format arguments
main.c:497: warning: format not a string literal and no format arguments
main.c:560: warning: format not a string literal and no format arguments
main.c:579: warning: format not a string literal and no format arguments
main.c:596: warning: format not a string literal and no format arguments
main.c:757: warning: format not a string literal and no format arguments
main.c:1104: warning: format not a string literal and no format arguments
main.c: In function ‘scan_bounds’:
main.c:1127: warning: format not a string literal and no format arguments
main.c:1178: warning: format not a string literal and no format arguments
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
I had the problem a few weeks ago.
In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
couldn't find ogr_srs_api.h
I edited /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h
and turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the
error and compiled properly.
Must be a change in the GDAL install. Any better idea welcome - this
is really just a hack.
Pierre
2011/6/21 Daniel Victoria <daniel.victoria@gmail.com>:
Thanks
Daniel
‘GPJ_grass_to_osr’
grass-user mailing list
grass-user@lists.osgeo.org
Scientist
Landcare Research, New Zealand
Hi Pierre,
I did the same thing you did and Grass compiled without errors. The
only difference is that I changed the file in grass_trunk/include.
Apparently, everything is working OK.
Daniel
On Tue, Jun 21, 2011 at 4:03 AM, Pierre Roudier
Pierre
Thanks
Daniel
‘GPJ_grass_to_osr’
Scientist
On Tue, Jun 21, 2011 at 2:28 PM, Daniel Victoria
<daniel.victoria@gmail.com> wrote:
Hi Pierre,
There was a compile flag missing for r.in.lidar, granted that
v.in.lidar was compiling ok without your fix. I have added the missing
compile flag to r.in.lidar, it should now compile without changing any
files in grass_trunk/include.
Markus M
Daniel
Pierre
Thanks
Daniel
‘GPJ_grass_to_osr’
Scientist
Thanks Markus - I'm glad there's a cleaner solution than that dirty hack!
I'll test it ASAP,
Pierre
2011/6/22 Markus Metz <markus.metz.giswork@googlemail.com>:
Hi Pierre,
Markus M
Daniel
Pierre
Thanks
Daniel
‘GPJ_grass_to_osr’
Scientist
Scientist
