[GRASS-user] grass70 problem with gui
Hi list,
After installin grass70 from "[http://ppa.launchpad.net/grass/grass-devel/ubuntu](http://ppa.launchpad.net/grass/grass-devel/ubuntu)" on Ubuntu 12.04 64, it fails to ``launch grass.
The wxpython gui gives the following error:
Launching GUI in the background, please wait…
GRASS 7.0.svn (utm32n):~ > ERRORE: MAPSET toscana - permesso negato
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 143, in
sys.exit(main())
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 136, in main
app = GMApp(workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 50, in init
wx.App.init(self, False)
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7981, in init
self._BootstrapApp()
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7555, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 84, in OnInit
workspace = self.workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py”, line 109, in init
self._menuTreeBuilder = LayerManagerMenuData()
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py”, line 40, in init
MenuTreeModelBuilder.init(self, filename, expandAddons=expandAddons)
File “/usr/lib/grass70/etc/gui/wxpython/core/menutree.py”, line 69, in init
xmlTree = etree.parse(filename)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1183, in parse
tree.parse(source, parser)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 657, in parse
self._root = parser.close()
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1655, in close
self._raiseerror(v)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1507, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Thanks a lot
Luca Angeli
You need to install the grass-gui package with
sudo apt-get install grass-gui
A colleague of mine had that same issue last week and that package resolved it
2013/12/10 Luca Angeli <lukangels@gmail.com>
Hi list,
sys.exit(main())
self._raiseerror(v)
raise err
Thanks a lot
Luca Angeli
grass-user mailing list
grass-user@lists.osgeo.org
César Augusto Ramírez Franco
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 301 389 5607
2013/12/10 Cesar Augusto Ramírez Franco <caesarivs@gmail.com>:
this is really strange. Isn't this package dependency of `grass`
package? In other word, shouldn't be installed automatically?
Martin
I used to compile it from trunk without problem in ArchLinux but since this morning I have the same error message.
g.version -g
version=7.0.svn
date=2013
revision=58433
build_date=2013-12-10
Are there any workaround ?
On Tue, Dec 10, 2013 at 4:37 PM, Ahmadou Dicko <dicko.ahmadou@gmail.com> wrote:
g.version -g
version=7.0.svn
date=2013
revision=58433
Ahmadou H. DICKO
statistician economist (Ingénieur Statisticien Économiste)
PhD candidate in Climate change economics
Faculty of economics and managment - Cheikh Anta Diop University
West African Science Service Center on Climate Change and Adaptated Land Use (WASCAL)
Center for Development Research (ZEF) - University of Bonn
email : ahmadou.dicko@ucad.edu.sn
twitter : @dickoah
github : github/dickoa
tel : +221 33 827 55 16
portable: +221 77 123 81 69
On Tue, Dec 10, 2013 at 4:30 PM, Martin Landa <landa.martin@gmail.com> wrote:
this is really strange. Isn’t this package dependency of grass
package? In other word, shouldn’t be installed automatically?
Martin
Ahmadou H. DICKO
twitter : @dickoah
2013/12/10 Ahmadou Dicko <dicko.ahmadou@gmail.com>:
g.version -g
version=7.0.svn
date=2013
revision=58433
I see, generating XML menu files seems to fail. At least on my PC
Generating interface description for all modules...
GISRC=/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
GISBASE=/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu
PATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts:$PATH"
PYTHONPATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib"
LC_ALL=C python tools/build_modules_xml.py >
/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/xml/module_items.xml
  File "tools/build_modules_xml.py", line 148, in <module>
    sys.exit(main())
  File "tools/build_modules_xml.py", line 133, in main
    header(fh)
  File "tools/build_modules_xml.py", line 94, in header
    (vInfo['version'].split('.')[0],
KeyError: 'version'
Unfortunately these kind of errors are not reported in error.log
(TODO: should be fixed).
Will have time to check it later unfortunately. Martin
On Tue, Dec 10, 2013 at 12:17 PM, Martin Landa <landa.martin@gmail.com>wrote:
this
> g.version -g
> version=7.0.svn
> date=2013
> revision=58433
    sys.exit(main())
    header(fh)
KeyError: 'version'
g.version -r is crashing for me, I just realized it.
Anna
2013/12/10 Anna Petrášová <kratochanna@gmail.com>:
right, I just realized it, it's related to r58417. Quickly fixed in
r58436 (back to the native tokenize soubroutine).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Thank you very much, it works now.
g.version -g
version=7.0.svn
date=2013
revision=58437
On Tue, Dec 10, 2013 at 5:35 PM, Martin Landa <landa.martin@gmail.com> wrote:
right, I just realized it, it’s related to r58417. Quickly fixed in
Martin
Ahmadou H. DICKO
twitter : @dickoah
On Tue, Dec 10, 2013 at 6:35 PM, Martin Landa <landa.martin@gmail.com> wrote:
I have fully reverted r58417 because with strtok, "A sequence of two
or more contiguous delimiter characters in the parsed string is
considered to be a single delimiter" (man strtok), whereas the
GRASS routine does not merge delimiters.
Markus M
2013/12/12 Markus Metz <markus.metz.giswork@gmail.com>:
why? It was useful, for example national DEM/DSM in Czech Republic
(sample data [1]) is provided in the format where coordinates are
separated with *two* or more spaces. In other words, with the native
tokenize function `r.in.xyz sep=space` or `r.in.xyz sep=" "`
(double-space as user could expect that it will work) fails bacouse
G_tokenize("x y", " "); returns {'x', '', 'y'} and not {'x', 'y'}.
With strtok-based tokenizing such string works perfectly.
BTW, `separator` parameter can be string with more than one character,
but native tokenize subroutine fails to tokenize such string with
multiple-character delimiter, eg. G_tokenize("firstSElast", "SE");
returns {'first', '', 'last'} and not {'first', 'last'} as someone
could expect.
Martin
[1] http://geoportal.cuzk.cz/UKAZKOVA_DATA/VYSKOPIS.zip
On Thu, Dec 12, 2013 at 12:10 PM, Martin Landa <landa.martin@gmail.com> wrote:
OTOH, v.in.ascii format=point expects the same number of tokens in each line:
1|1||name
2|2|3|other_name
must always result in 4 tokens. Here, double pipe works as expected
only if delimiters are not merged.
could expect.
Someone else would expect that with "SE" as delimiter argument, the
delimiter can be either "S" or "E".
I would leave G_tokenize() as it is because it is used at too many
different places which expect the current behaviour.
It is not uncommon that ASCII input data need a bit of pre-processing
(tr, sed), e.g. when fields have fixed lengths. Alternatively, add an
option (to respective modules, not to G_tokenize()) to expect fixed
length fields defining the field lengths?
Markus M
1|1||name
2|2|3|other_name
right, we need to have native tokenize() subroutine for such cases. It
was not good idea to replace it directly with tokenize_strtok() even
as a test. Anyway my plan was to introduce a new G_tokenize3() or
G_tokenize_strtok() based on tokenize_strtok(). I believe that such
function would make sense on several places like in `r.in.xyz`.
could expect.
right, as strtok() behaves.
Agreed.
right, anyway I think it's still better to handle such issues on
module level. You can hardly ask Windows user to use `tr` or `sed`.
Being user friendly is not so bad idea.
I still think that G_tokenize_strtok() would make sense to have. Then
`r.in.xyz` or `v.in.ascii` could have special flag which could handle
input files as I described (e.g. columns separated by two spaces).
What do you think?
Martin
