[GRASS-user] grass73: python module name issue
   When I start grass73 I see this in a virtual console:
Welcome to GRASS GIS 7.3.svn (r69357)
Launching <wxpython> GUI in the background, please wait...
GRASS 7.3.svn
(Oregon-Dayton):~/projects/oregon/washington-eichler/data/topography >
Numeric,numarray or NumPy not found.
             This module requires the Numeric/numarray or NumPy module,
             which could not be imported. It probably is not installed
             (it's not part of the standard Python distribution). See the
             Numeric Python site (http://numpy.scipy.org) for information on
             downloading source or binaries.
(Repeated 3 more times.)
   However, that module is installed, but is named numpy, not NumPy:
$ ls /var/log/packages/ | grep numpy
numpy-1.9.1-i486-1_SBo
Python 2.7.5 (default, May 29 2013, 03:26:28) [GCC 4.8.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
import numpy
   Can this be quickly fixed?
TIA,
Rich
   Also happens with 7.2.svn (r69323M).
Rich
On Tue, Sep 6, 2016 at 4:39 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Rich
Can you run 'import numpy' for example from GUI Python shell?
The imports in GUI look correct to me.
Anna
grass-user mailing list
grass-user@lists.osgeo.org
Anna,
   Yes:
GRASS 7.3.svn
(Oregon-Dayton):~/projects/oregon/project/data/topography >
python
import numpy
   Does this mean I ignore the startup errors?
Rich
On Tue, Sep 6, 2016 at 7:31 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Anna,
  Yes:
GRASS 7.3.svn
python
import numpy
the error means that 'import numpy' fails, so I am surprised it works
for you otherwise. The import happens in gui_core/wxlibplot.py,
wxplot/profile.py and nviz/wxnvix.py if you want to investigate more.
Rich
   Thought so.
... so I am surprised it works for you otherwise. The import happens in gui_core/wxlibplot.py, wxplot/profile.py and nviz/wxnvix.py if you want to
investigate more.
   I'll look at them tomorrow. When I grep'd the source tree it looked like
NumPy is found in many files, but most of those are error message strings.
Thanks, Anna,
Rich
# Needs NumPy
try:
     import numpy as np
   Therefore, this should work.
wxplot/profile.py,
try:
     import numpy
   Therefore, this also should work.
and nviz/wxnvix.py
try:
     from numpy import matrix
   And, this too should work.
   All three modules call for numpy (lowercase). That's how it's imported
here both within the grass console and a non-grass console.
   What do you suggest as further investigation why the error message appears
when I invoke grass?
Rich
On Tue, Sep 6, 2016 at 8:12 PM, Rich Shepard <rshepard@appl-ecosys.com>
appears
You can try the following commands in and outside of GRASS GIS session:
echo $GRASS_PYTHON
which python
python -c "import sys; print(sys.path)"
python -c "import numpy"
Vaclav
On Tue, Sep 6, 2016 at 7:31 PM, Rich Shepard &lt;
rshepard@
Anna,
  Yes:
GRASS 7.3.svn
python
import numpy
Rich
grass-user@.osgeo
grass-user@.osgeo
there is already a ticket for this in OSGEO4W-winGRASS; the interesting
thing is that this issue isn't in standalone winGRASS of the same version.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/grass73-python-module-name-issue-tp5284395p5284428.html
thing is that this issue isn't in >standalone winGRASS of the same version.
https://trac.osgeo.org/grass/ticket/3057
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/grass73-python-module-name-issue-tp5284395p5284452.html
echo $GRASS_PYTHON
which python
Vaclav,
   External to grass:
$ echo $GRASS_PYTHON
$ which python
/usr/bin/python
$ python -c "import sys; print(sys.path)"
['', '/usr/lib/python2.7/site-packages/python_dateutil-2.2-py2.7.egg',
'/usr/lib/python2.7/site-packages/SQLAlchemy-1.0.8-py2.7-linux-i686.egg',
'/usr/lib/python2.7/site-packages/flake8-2.4.1-py2.7.egg',
'/usr/lib/python2.7/site-packages/mccabe-0.3.1-py2.7.egg',
'/usr/lib/python2.7/site-packages/pep8-1.5.7-py2.7.egg',
'/usr/lib/python2.7/site-packages/pyflakes-0.8.1-py2.7.egg',
'/usr/lib/python2.7/site-packages/gtimelog-0.10.0-py2.7.egg',
'/usr/lib/python27.zip', '/usr/lib/python2.7',
'/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
'/usr/lib/python2.7/site-packages', '/usr/lib/python2.7/site-packages/PIL',
'/usr/lib/python2.7/site-packages/geos',
'/usr/lib/python2.7/site-packages/gtk-2.0',
'/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode']
$ python -c "import numpy"
   Using grass72 console:
echo $GRASS_PYTHON
python
which python
/usr/bin/python
  '/usr/local/grass-7.2.svn/etc/python', '/usr/lib/python27.zip',
  '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
  '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
  '/usr/lib/python2.7/lib-dynload', '/usr/lib/python2.7/site-packages',
GRASS 7.2.svn
   The environment variable GRASS_PYTHON is set with grass running, but not
otherwise.
Rich
Helmut,
   This references two Windows flavors. I run Slackware-14.1 (soon to be
upgraded to -14.2).
Rich
On Wed, Sep 7, 2016 at 9:22 AM, Rich Shepard <rshepard@appl-ecosys.com>
GRASS 7.2.svn
I suppose this means no output. No traceback means that it works. So numpy
works in the GRASS GIS session and it works outside.
otherwise.
That's correct I think. It is set for consistency. (You could use it to
force some other Python executable.)
OK, still no clues for me. Can you run the GUI (what you get when you start
or/and g.gui from command line - there should be no difference but you can
check), switch to Python tab and execute:
import sys
print (sys.path)
print (sys.version)
import numpy
Also, you can check which Python version is used in the command line:
python --version
Finally, you can try to find where numpy actually is and compare it with
what sys.path is saying.
Vaclav,
   Correct.
import sys
print (sys.path)
print (sys.version)
import numpy
   Cannot copy from the tab window to here. See attached .png.
python --version
$ python --version
Python 2.7.5
/usr/lib/python2.7/site-packages/numpy
   It seems that sys.path is not picking up this package. Interesting.
HTH,
Rich
(attachments)
On Wed, Sep 7, 2016 at 11:52 AM, Rich Shepard <rshepard@appl-ecosys.com>
The Python the Python tab in GUI *is* the Python running the GUI. If it is
able to import numpy there, it should be able to import it during startup.
Does the g.gui give you the numpy messages?
I can see the `/usr/lib/python2.7/site-packages` path in all the sys.path
lists you posted. If numpy is a subdir with __init__.py, then Python should
pick it up. Although numpy is a bit special since it has also a C part...
I can copy with wxPython: 3.0.2.0 (and Python 2.7.10, any GRASS).
   And that's what the first line in the tab display box indicates.
If it is able to import numpy there, it should be able to import it during
startup.
   That it is not importing during startup is the problem here that needs
fixing.
   Not in the GUI window, but in the virtual console, yes.
GRASS 7.3.svn (Oregon-Dayton):~ > Numeric,numarray or NumPy not found.
   Displayed 3 times, once for each file seeking to access numpy.
should pick it up. Although numpy is a bit special since it has also a C
part...
   It should also work with wxPython-2.8.12.1 and python-2.7.5. But, when I
highlighted the text with the trackball it would not paste in the alpine
urxvt window. Alpine's a text-based MUA, not a GUI-based one.
Rich
version.
Helmut,
upgraded to -14.2).
Rich
grass-user@.osgeo
Yes, reported on windows, but the same issue.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/grass73-python-module-name-issue-tp5284395p5284576.html
Helmut,
   Can we who are affected expect a fix soon? I've a client who needs the
results of topographic and hydrologic modeling, and sooner is better than
later.
   If I can assist I'll certainly do so.
Rich
Helmut,
later.
Rich
grass-user@.osgeo
all C GRASS modules and most python GRASS modules are working here ; so
modelling should be possible.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/grass73-python-module-name-issue-tp5284395p5284582.html
Helmut,
   Good. I'll proceed, then.
Rich
