[GRASS-user] grass78 on centos7 from coprs/neteler/grass78
Dear list,
I am trying to install grass78 on centos7.
I am following the instructions here: https://copr.fedorainfracloud.org/coprs/neteler/grass78/
However when trying to download the file https://copr.fedoraproject.org/coprs/neteler/grass78/repo/epel-7/neteler-grass78-epel-7.repo I get “Error 404: Not Found Chroot epel-7 does not exist in neteler/grass78”
I am wondering if maybe the file is in some slightly different path or if I m doing something wrong
Thank you very much in advance
Laura
Dear Laura,
On Thu, Oct 24, 2019 at 8:24 AM Laura Poggio <laura.poggio@gmail.com> wrote:
Dear list,
However when trying to download the file https://copr.fedoraproject.org/coprs/neteler/grass78/repo/epel-7/neteler-grass78-epel-7.repo I get "Error 404: Not Found Chroot epel-7 does not exist in neteler/grass78"
Nothing wrong at your end, but at "my" end. I just see that EPEL7
compilation was deactivated.
I have now enabled it and started the compilation [1]. I hope it goes through.
Will let you know as soon as I get the result.
[1] https://copr.fedorainfracloud.org/coprs/neteler/grass78/build/1078463/
Best regards
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Dear Markus,
thank you very much. Your repositories for fedora and centos are really very helpful in avoiding the compilation from source.
Thanks a lot
Laura
On Thu, 24 Oct 2019 at 11:56, Markus Neteler <neteler@osgeo.org> wrote:
Dear Laura,
Dear list,
Nothing wrong at your end, but at “my” end. I just see that EPEL7
Best regards
Markus Neteler, PhD
Dear Laura,
On Thu, Oct 24, 2019 at 12:12 PM Laura Poggio <laura.poggio@gmail.com> wrote:
Dear Markus,
Happy to help :slight_smile:
Right now we are stuck at this:
No matching package to install: 'python3-numpy'
No matching package to install: 'python3-dateutil'
It seems that the name is (https://pkgs.org/download/python36-numpy) this one:
python36-numpy
python36-dateutil
Means I have to update the SPEC file to add more special rules for
EPEL7... I try asap.
Best
Markus Neteler, PhD
Hi again,
Seems I got it :slight_smile:
Please note that I also fixed a typo in the EPEL7 install step in above page.
Please let me know if it now works for you,
Best
Markus Neteler, PhD
Dear Markus,
I tried and I get
Error: Package: grass-7.8.0-4.el7.x86_64 (copr:copr.fedorainfracloud.org:neteler:grass78)
Requires: python3-numpy
Requires: python3-matplotlib
yum lists
python34-numpy.x86_64 : A fast multidimensional array facility for Python 3.4
python36-numpy.x86_64 : A fast multidimensional array facility for Python 3.6
but not exactly python3-numpy or python3-matplotlib. I installed python36-numpy.x86_64 and python36-matplotlib.x86_64
I also tried to install from https://copr.fedorainfracloud.org/coprs/neteler/python-matplotlib/ but I could not get past the error above.
Maybe it is something on how it is necessary to refer to python3 in centos?
I tried both with conda and with python3 from yum.
Thanks a lot!
Laura
On Thu, 24 Oct 2019 at 15:04, Markus Neteler <neteler@osgeo.org> wrote:
Hi again,
EPEL7… I try asap.
Best
Markus Neteler, PhD
Dear Laura,
I forgot to encapsulate two more statements. It has been compiled again.
Please give it a new try.
ciao
Laura Poggio <laura.poggio@gmail.com> schrieb am Do., 24. Okt. 2019, 16:27:
Dear Markus,
I tried and I get
yum lists
Thanks a lot!
Laura
Hi again,
EPEL7… I try asap.
Best
Markus Neteler, PhD
Dear Markus,
the main installation worked fine. Thanks a lot!
One more question. I installed grass-gui as well withou problems or errors
When I start GRASS I get the message: ERROR: wxGUI requires wxPython. No module named ‘wx’
I installed wxPython (and its devel) with yum but I think it is not the right version. I tried to installed it within conda environments or using pip3, but the installation is giving errors.
Before I start to dig into it, I was wondering if there is some quick solution to get the right wxPython?
Thanks a lot again!
Laura
On Thu, 24 Oct 2019 at 20:26, Markus Neteler <neteler@osgeo.org> wrote:
Dear Laura,
ciao
Dear Markus,
I tried and I get
yum lists
Thanks a lot!
Laura
Hi again,
EPEL7… I try asap.
Best
Markus Neteler, PhD
Dear Laura,
On Fri, Oct 25, 2019 at 9:40 AM Laura Poggio <laura.poggio@gmail.com> wrote:
Dear Markus,
glad it installs now, at least without the GUI.
When I start GRASS I get the message: ERROR: wxGUI requires wxPython. No module named 'wx'
In GRASS 7.8, we moved to Python 3.
In Fedora, we use python3-wxpython4 to compile wxGUI:
- https://koji.fedoraproject.org/koji/packageinfo?packageID=26351
However, I don't know where to find a corresponding EPEL package:
- https://centos.pkgs.org/7/epel-x86_64/wxPython-2.8.12.0-9.el7.x86_64.rpm.html
- https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/w/
Does anyone have an idea? Maybe I am missing something.
thanks
Hi again,
I now briefly talked to the wxPython EPEL maintainer, and opened a
related ticket:
https://bugzilla.redhat.com/show_bug.cgi?id=1765573
Hope it get's packaged soon.
Best,
thanks a lot!
In the meantime I can use the png monitor if really needed (working on a cloud machine on a storage type I can not really mount locally).
Thanks a lot
Laura
On Fri, 25 Oct 2019 at 15:02, Markus Neteler <neteler@osgeo.org> wrote:
Hi again,
However, I don’t know where to find a corresponding EPEL package:
related ticket:
Hope it get’s packaged soon.
Best,
Hi Laura,
Today the EPEL package reached "testing":
https://bodhi.fedoraproject.org/updates/FEDORA-EPEL-2019-8d020579ef
You may want to test it and leave "karma" there (positive or negative)
in order to let the packager know that things work (or not).
Best
On Fri, Oct 25, 2019 at 3:36 PM Laura Poggio <laura.poggio@gmail.com> wrote:
thanks a lot!
Thanks a lot
Laura
Hi again,
related ticket:
Best,
Markus Neteler, PhD
Dear Markus,
I will do it as soon as possible.
Thanks
Laura
On Tue, 19 Nov 2019 at 10:11, Markus Neteler <neteler@osgeo.org> wrote:
Hi Laura,
Today the EPEL package reached “testing”:
You may want to test it and leave “karma” there (positive or negative)
Best
thanks a lot!
Thanks a lot
Laura
Hi again,
related ticket:
Best,
Markus Neteler, PhD
El mié., 20 nov. 2019 7:11 a. m., Laura Poggio <laura.poggio@gmail.com> escribió:
Dear Markus,
Thanks
Laura
Hi Laura,
Best
thanks a lot!
Thanks a lot
Laura
Hi again,
related ticket:
Best,
Markus Neteler, PhD
grass-user mailing list
grass-user@lists.osgeo.org
Hi Laura,
On Tue, Nov 19, 2019 at 10:11 AM Markus Neteler <neteler@osgeo.org> wrote:
Hi Laura,
FYI - update:
python-wxpython4-4.0.7-4.el7 has been pushed to the Fedora EPEL 7
stable repository.
(I suppose that it will be available for EPEL 8 either soon or it is
already there.)
I have now triggered the GRASS GIS compilation on COPR again.
Best,
Dear Markus,
thanks for this!
I will test as soon as I can this week
Thanks a lot
Laura
On Sat, 7 Dec 2019 at 18:11, Markus Neteler <neteler@osgeo.org> wrote:
Hi Laura,
Hi Laura,
FYI - update:
stable repository.
already there.)
Best,
Dear Markus,
it works fine with the latest version of grass (7.8.2 from coprs/neteler/grass78/) on centos 7. I did not test with previous versions.
I will try to test the whole workflow on centos 8 soon(ish).
Thank you very much!
Laura
On Mon, 9 Dec 2019 at 07:46, Laura Poggio <laura.poggio@gmail.com> wrote:
Dear Markus,
thanks for this!
Thanks a lot
Laura
Hi Laura,
Hi Laura,
FYI - update:
stable repository.
already there.)
Best,
