[GRASS-user] [GRASSLIST:1079] grass database and dbms
Hello :slight_smile:
I was wondering if GRASS, with SQL support, needs or uses some kind of dbms like MySql or PostgreSQL.
Can anyone help me? Where can I find documentation about this subject ?
Thanks :slight_smile:
hallo
it can use PostgreSQL directly,
http://grass.itc.it/grass61/manuals/html61_user/databaseintro.html
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
It can connect to either.see db.connect.
  http://grass.ibiblio.org/grass61/manuals/html61_user/database.html
The default is simple DBF, which can use simple SQL support (limited).
Also simple is SQLite but that can understand more/most SQL statements.
MySQL is supported, but apparently there are issues?
PostgreSQL is supported quite well, if I understand correctly.
With ODBC you can connect with Oracle, etc....
http://grass.ibiblio.org/grass61/manuals/html61_user/sql.html
http://grass.ibiblio.org/grass61/manuals/html61_user/databaseintro.html
http://grass.itc.it/grass57/tutorial/links.html
Hamish
I've been using sqlite for the last few months on several of my
projects. I think it works rather well. It supports almost all of SQL,
so there are no artificial limitations. It is very easy to learn and
use. The databases are stored in a single file and appear to be
portable across platforms (windows and linux at least).
The only issues I have found---and these are only things you would
notice coming from other databases---is that it has no column typing
(you can load a double into a varchar column) and modifying tables
(like dropping columns) usually involves copying the entire table via
a select statement.
I would recommend sqlite over dbf.
Hamish
grassuser mailing list
grassuser@grass.itc.it
David Finlayson
