Hello GRASS users
I have recently installed GRASS6 on win 98 systems using the
cygwin environment by creating a CD from iso file. It works fine on all systems.
however on one of the system it doesnt work fine.
i get the following error
"Out of environment space"
Also all the GRASS commands works fine.
But d.mon doesnt open up a monitor.
It opens the monitor only for a split second
and then the monitor closes.
Kindly help
I read archives to find the following
- Click on the MS-DOS prompt icon to get a shell window.
- Click on the fifth button from the left--the one that has a
"Properties"
tool tip when you hover over it with the mouse.
- Click on the "Memory" tab.
- In "Initial
Environment", change the selection from "Auto"
to "4096" - Click "Ok".
- You'll get a warning dialog "The changes made to memory setting(s)
will not take effect until you restart the program". Click "Ok" to dismiss that dialog.
- Close the shell window.
- Click on the MS-DOS prompt icon again to get a new shell window. Run
BlueJ from that window.
- From now on, all new shell windows will have the increased environment
space.
Pls send any suggestions to make my GRASS monitor open
and also to remove the out of environment space error
Rochelle
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1ยข/min.
AFAIK GRASS can run only or Windows NT+ (2000, XP, 2003)
Jachym
On Tue, May 30, 2006 at 09:21:51PM -0700, Rochelle MIranda wrote:
Hello GRASS users
Kindly help
"Properties"
- In "Initial Environment", change the selection from "Auto"
space.
Rochelle
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
Assuming that your machine is vintage windows 98, and you really want
GRASS to work on your current hardware. You might try installing a
light-weight GNU/Linux distribution and try GRASS that way.
I've read good things about DSL and XUbuntu (Google for these). Both
are designed to run in low-specification machines.
David
Jachym
> Hello GRASS users
> Kindly help
> "Properties"
> space.
> Rochelle
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
iD8DBQFEfUkjyKt0uAjU4I8RAuz/AJwLuIlGoE93QK2WYERIgB50uW7gTwCgr+q6
PWor0FKt6D1U1P8t/pRsVCA=
=JhjA
-----END PGP SIGNATURE-----
David Finlayson
