when i run the v.distance command i get this error, “WARNING: coor files of vector ‘pseudolink2@PERMANENT’ is larger than it should be (14 bytes excess).”
i’m hoping to build an output file of lines, that connect my “from” dataset (points) to the “to” dataset (lines/roads).
upon browsing the output data, it seems like it built the lines. but there is a scrolling, repeated error in the output box for the command “Column ‘distance’ not found” “Error in db_execute_immediate()”
I did specify upload=dist and column=distance.
Do i have to add the distance colum to the points and/or lines before hand? it seems so, but i would have thought the distance would have been calculated into the output file?
