[GRASS-user] [GRASSLIST:1135] Qn. on extracting from multiple rasters, data corresponding to vector polygons
I have a vector polygon shapefile which contains 8 polygons (each watershed is a polygon). I also have some 100 GRASS raster files of environmental data (rainfall, temperature etc).
Whats the best way to extract for each watershed, the corresponding average data from each raster file and put it in a text file?
I’ve looked at v.what.rast but it seems to be quite cumbersome for this application. I’m using Grass 6.0.1 on Ubuntu linux.
cheers,
vishal
Hallo,
On Tue, Jun 27, 2006 at 04:16:38PM +0530, Vishal Mehta wrote:
I've looked at v.what.rast but it seems to be quite cumbersome for this
application. I'm using Grass 6.0.1 on Ubuntu linux.
cheers,
vishal
v.type in=polygons out=polygons2 type=centroid,point
v.to.rast in=polygons2 out=wathershed use=cat
r.average base=wathershed cover=rainfalls out=rainfalls.avg
echo "ALTER TABLE polygons2 ADD COLUMN rainfalls double"|db.execute
v.what.vect vect=polygons2 rast=rainfalls.avg coulmn=rainfalls
v.type in=polygons2 out=polygons3 type=point,centroid
d.vect polygons3
d.what.vect polygons3
in the batch:
# convert centorids to points
# make 100 rasters
for raster in $( g.mlist rast ); do
    echo "Working on: $raster"
    r.average base=wathershed cover=$raster out=$raster.avg
    echo "ALTER TABLE polygons2 ADD COLUMN $raster double"|db.execute
    v.what.vect vect=polygons2 rast=$raster.avg coulmn=$raster
# convert points to centroids
d.vect polygons3
copy & paste
jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
eehm:
# make 100 rasters
      done
d.vect polygons3
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
On Tuesday 27 June 2006 03:46, Vishal Mehta wrote:
cheers,
vishal
if you have the ability to compile from source code, try starspan.
http://starspan.casil.ucdavis.edu/?StarSpan
Matt Perry has a nice demo here:
http://www.perrygeo.net/wordpress/?p=30
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Vishal:
            We designed starspan to do exactly this - one of these days
we'll mod it so it works from within grass: starspan.casil.ucdavis.edu .
--j
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Phone: 415-794-5043
AIM: jgrn3007
MSN: jgrn3007@hotmail.com
  _____
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] On
Behalf Of Vishal Mehta
Sent: Tuesday, June 27, 2006 3:47 AM
To: GRASS Users list
Subject: [GRASSLIST:1135] Qn. on extracting from multiple rasters, data
cheers,
vishal
Thanks all (esp. Jachym, Dylan, Jonathan)
Dylan/Jonathan, I havent tried Starspan, but it
looks good. i’ll get into it if i find i have to. I cant compile from sourcecode since i’m not that Linux savvy.
Jachym, I tried your approach on a small set of 12 rasters. v.what.vect is not there in my Grass 6.0.1; but i was able to do the same thing with v.what.rast
Basically values from each raster were added on as a column in the vector attribute table. Thanks Jachym!
However, even with just 12 rasters, it took a bit of time (~10 seconds). With some 100 rasters to process at a time, I have the following doubts:
  1. Can the vector attribute table handle 100 additional tables, or is there a limit?
  2. My rasters are large, covering south asia (60E-100E, 5N-45N; 0.5 degree resolution). My vectors are very small (covering small part of south-west India). Perhaps this effects the processing time…should i mask the rasters and then do the adding of columns?
  3. Since my watershed are small, most fall within one pixel. When they do cross 2 pixels, the v.to.rast clips the raster watershed to one pixel. Any suggestion on perhaps better ways of handling this?
Thanks very much!
cheers,
vishal
On 6/27/06, Jachym Cepicky <jachym.cepicky@centrum.cz> wrote:
Hallo,
cheers,
vishal
echo “ALTER TABLE polygons2 ADD COLUMN rainfalls double”|db.execute
d.vect polygons3
in the batch:
make 100 rasters
echo “Working on: $raster”
echo “ALTER TABLE polygons2 ADD COLUMN $raster double”|db.execute
d.vect polygons3
copy & paste
jachym
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (GNU/Linux)
iD8DBQFEoSC6yKt0uAjU4I8RAs7bAJ0VbEJZ7763uMKCL7HPRQvCk7XztQCfarwE
yKmI8KxGdTk0qskBiEFSE2E=
=CJ47
-----END PGP SIGNATURE-----
this application. I'm using Grass 6.0.1 on Ubuntu linux.
I think this can be easily done.
why not just
g.region rast=biggest_map
v.to.rast in=vectmap out=watersheds use=cat # or attr if ID column exists
r.mapcalc "MASK=if(watersheds == 1, 1, null() )"
r.univar rainfall
putting that in a loop:
g.region rast=typical_map
r.info -r watersheds
min=1
max=8
eval `r.info -r watersheds`
#if IDs are not sequential use
# for WATERSHED in `r.stats -qn watersheds` ; do
# this is untested, but the general method works
echo "watershed|map|average_val" > results.txt
for WATERSHED in `seq $min $max` ; do
  g.remove MASK
  unset MEAN
  echo "Watershed: $WATERSHED Map: $MAP"
  r.mapcalc "MASK=if(watersheds == $WATERSHED, 1, null() )"
  for MAP in `g.mlist type=rast pat=* fs=space` ; do
     #g.region rast=$MAP # adjust to match res of each map
     MEAN=`r.univar -g $MAP | grep '^mean=' | cut -f2 -d=`
     echo "$WATERSHED|$MAP|$MEAN" >> results.txt
  done
done
g.remove MASK
if maps are all different sizes and resolutions do the v.to.rast
step at the finest resolution to avoid aliasing problems.
good luck,
Hamish
south-west India). Perhaps this effects the processing time..should i
add in a step after MASK creation:
g.region zoom=MASK res=0.5 -a
leave out the g.mlist sep=space, it uses the whole word!
`g.mlist pat='*'` is enough.
Hamish
ps - new mailing list address: grassuser at grass.itc.it
I had, with your help, added 500 columns of rain data from 500 corresponding rasters, t0 my vector map of 8 watersheds.
Now i want to add another 500 columns to the same vector map, but from different 100 rasters, namely derived reference ET maps i have created.
My qna are:
  1. Should i use the same table but first connect to a different empty ‘layer’ first using v.db.connect?
  2. If i do the above, will i be able to extract individual layers of the table in openoffice calc or Excel?
  3. i was going to just copy my vector map and then delete the original 500 rain columns from the table, and then add the 500 ET columns- but i was not able to do it. i tried commands like
    echo “DELETE COLUMN ‘Rain1’ FROM watershed8c” | db.execute
and
echo “DELETE FROM watershed8c COLUMN LIKE ‘rain’” | db.execute
but they did’nt work.
How do i delete say all columns that start with the text ‘rain’ from a table?
thanks much,
vishal
On 6/28/06, Hamish <hamish_nospam@yahoo.com> wrote:
Vishal Mehta wrote:
  1. My rasters are large, covering south asia (60E-100E, 5N-45N; 0.5
g.mlist pat='*' is enough.
Hamish
echo "DELETE COLUMN 'Rain1' FROM watershed8c" | db.execute
and
echo "DELETE FROM watershed8c COLUMN LIKE 'rain'" | db.execute
but they did'nt work.
How do i delete say all columns that start with the text 'rain' from a
table?
I'm not sure, but the DBF driver may not support "DELETE" ?
Make a new table, copy columns you want to keep, v.db.droptable the old
table? or use another db?
Hamish
table?
Correct. Neither DROP COLUMN will work. Neither in SQLITE doesn't. A
workaround: http://grass.gdf-hannover.de/wiki/Sqlite_Drop_Column
Postgres and Mysql support DROP COLUMN.
Maciek
