[GRASS-user] [GRASSLIST:1147] xganim Error: attempt to add non-widget child "DropSiteManager" to parent "xganim" which supports only widgets
Dear GRASS users.
I have mandriva 2006 linux OS. After installing lesstif-0.95.0.tar.gz (Containing the Xm library) ,
I installed the xganim module of GRASS 6.0 successfully.
However i get the following error at run time:
Warning: XmManager ClassInitialize: XmeTraitSet failed
Kindly drop in suggestions to fix this error.
Regards
Nagesh
