Maciej Sieczka <tutey@o2.pl> wrote:
Hardeep Singh Rai napisa?(a):
On GRASS6.0.2 on debian, v.digit is giving segmentation fault. Listing
is given below. What is wronmg?
Can you reproduce this with any vector, or only this one?
With al vebtors, rather on two different machines, both running Debian.
May be same setup in all respect
What does "v.info v3" say?
cannot open old vector v3@hsrai on level 2
If you run "v.build v3", then v.digit - does that help?
v.build correct above mentioned problem. But on v.digit, it gave
"segmentaion fault" and on v.info again give same error of "cannot open
old vector v3@hsrai on level 2".
P.S. Quit using grasslist@baylor.edu. It is deprecated.
Thanks for correcting me.
H.S.Rai
http://www.fastmail.fm - Same, same, but different…
