[GRASS-user] [GRASSLIST:1156] v.digit: Segmentation fault
Maciej Sieczka <tutey@o2.pl> wrote:
Hardeep Singh Rai napisa?(a):
On GRASS6.0.2 on debian, v.digit is giving segmentation fault. Listing
is given below. What is wrong?
Can you reproduce this with any vector, or only this one?
With all vectors, rather on two different machines, both running Debian.
May be same setup in all respect :frowning:
What does "v.info v3" say?
cannot open old vector v3@hsrai on level 2
If you run "v.build v3", then v.digit - does that help?
v.build correct above mentioned problem. But on v.digit, it gave
"segmentaion fault" and on v.info again give same error of "cannot open
old vector v3@hsrai on level 2".
P.S. Quit using grasslist@baylor.edu. It is deprecated.
Thanks for correcting me.
H.S.Rai
H.S.Rai napisa?(a):
I don't have any more reasonable ideas. Maybe try another TCL/TK version
(Debian should provide 8.3 and 8.4)?
On Ubuntu Breezy and Dapper it is not segfaulting in Grass 6.1. Can you
try it on your Debian machines?
Also, read this, looks similar to your problem:
http://intevation.de/rt/webrt?serial_num=4184
http://intevation.de/rt/webrt?serial_num=4380
It is always a good idea to take a look at the bugtracker and
grass-commit archive to check if somebody had/fixed the bug.
Maciek
