Hi list,
A short question on sql-commands in GRASS: is there a possibility to use
wildcards in sql-statements? Using QGIS, I found out that the advance search
function does allow statements like [coloum name] like 'Pattern%', but this
does not work with GRASS. "*" also does not do the job...
Best regards,
Wolfgang
wqual wrote on 08/02/2006 08:36 AM:
Hi list,
Best regards,
Wolfgang,
GRASS 6.1 supports wildcards (the DBF driver limited, the other drivers
like standard SQL):
http://grass.itc.it/pipermail/grass-dev/2006-July/024473.html
http://grass.itc.it/grass61/manuals/html61_user/sql.html
-> Example of pattern matching
cheers
PS: please use grassuser@grass.itc.it instead of the old
grasslist@baylor.edu
