[GRASS-user] [GRASSLIST:1175] add centroids automatically to area boundaries
Dear list,
I am trying to solve the impossible it seems. I have the following
problem:
I have a patched vector map with lines. These lines should be converted
into area boundaries in order to receive areas. Once boundaries are
retrieved I still need to attach centroids to them in order to overlay
with *another* vector map which already consists of boundaries and areas
including centroids. How can I achieve this?
I tried to convert all lines into boundaries with
v.type type=line,boundary
It seems to work as there are only boundaries left. Next step would be
to add automatically centroids to these boundaries. How can this be
done?
Ulrich
On Thu, Aug 10, 2006 at 03:04:05PM +0200, Ulrich Leopold wrote:
Dear list,
problem:
done?
see v.category for this. I have added a micro FAQ for this:
http://grass.gdf-hannover.de/wiki/Convert_vector_types
hope this helps,
Dear list,
problem:
done?
I tried that already but it did not work. It even changes the polygons back to
single lines. But good that you opened a micro FAQ to add the solution later.
Any other ideas?
Ulrich
areas
done?
back to
later.
Any other ideas?
Are you sure your lines are closed, thus defining real areas ? You can
check with v.digit.
Moritz
isn’t v.clean using input lines, output polygons, applicable here? should take lines and build for polygons and add centroids? or am i missing something…
with another vector map which already consists of boundaries and
areas
done?
back to
later.
Any other ideas?
check with v.digit.
Moritz
grassuser mailing list
grassuser@grass.itc.it
areas
done?
back to
later.
Any other ideas?
check with v.digit.
I put a screenshot on the WiKi page:
The lines seem to be closed. But a lot of boundaries are without areas as you
can see from the legend on the right hand side.
And v.clean does not do the job. I used v.type to convert from lines to
boundaries.
So possibly that the problem are boundaries with no areas? But then how can I
change that?
areas
done?
back to
later.
Any other ideas?
check with v.digit.
No, all the red nodes are nodes with only one line connected to them, so they are not closed.
could you be more precise ? What options did you use ? Did you try the "snap" tool ? With what threshold ? What does "does not do the job" mean ?
boundaries.
This means you just converted the types, but if the lines are not closed it is not enough.
change that?
Close the lines.
Moritz
problem:
converted into area boundaries in order to receive areas. Once
boundaries are retrieved I still need to attach centroids to them in
order to overlay with *another* vector map which already consists of
boundaries and areas including centroids. How can I achieve this?
done?
v.category option=add
Hamish
